Old 10-09-2017, 08:19 PM   #1
packrat5
Default Truck rear axel
51 Ford F-1 pickup with a Dana 44. How many spline axels does it have?
packrat5 is offline   Reply With Quote
Old 10-10-2017, 09:32 AM   #2
GB SISSON
GB SISSON's Avatar
Default Re: Truck rear axel
I think that would be a retro-fit axle. You should get a picture and post it on FTE (Ford truck enthusiasts) in the '48-51 group. Usually about 375 guys on there at any given time with your vintage of truck.
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1947 Tonner Pickup (red) mostly stock with exception of a cummins 6at turbo diesel, 1946 Tonner Pickup (green) with 226 cu in 6 cyl flathead, 1979 Toyota landcruiser wagon, completely encased in 1947 Ford Jailbar sheet metal. Ok, cornbinder rear fenders..... 'Rusty ol' floorboards, hot on their feet' (Alan Jackson)
Old 10-10-2017, 10:14 AM   #3
packrat5
For Pete"s sake, it's not a "retrofit". The thing still has the original brakes on it
Old 10-10-2017, 12:05 PM   #4
1952henry
1952henry's Avatar
According to ringpinion.com, it is 19 spline. Not my business, but no need to jump ugly with GB. He was only trying to help.
I dig coal, which provides motivation for EVs.
1952henry is offline   Reply With Quote
Old 10-10-2017, 12:09 PM   #5
1952henry
1952henry's Avatar
You could check with chuck mantiglia at chuckstrucks. He no doubt has been into many of these axles
Old 10-10-2017, 01:59 PM   #6
packrat5
Okay, I apologize. I was trying to avoid pulling an axel, and then reassembling it, and pulling it apart again when all the parts come.
Old 10-10-2017, 02:17 PM   #7
rotorwrench
rotorwrench's Avatar
Early Dana 41 & 44 have the 19-spline axle shafts. This includes 1/2 ton F1 pickups, Mercury cars & station wagons, Ford station wagons, and purpose built police cars. Ford used them for many years but the later ones have a lot more splines.
Dana 41 was used for 1948/49/ & early 1950 F1. The Dana 44 came along for later 1950 through end of F1 production. Even some of the later F100 pickups used them but they were a bit different than the F1 types if I remember correctly. All of them use the same basic rear brake set up way up into the last of the 5 X 5.5" bolt pattern.
Old 10-10-2017, 07:32 PM   #8
packrat5
That's the information I wanted. Yes it is a Dana 44. Thanks.
