10-03-2021, 08:29 PM | #1 |
My first tow! Starter not cooperative
My starter won't activate. It does a single click when I step on it which sounds like the electric connection, not the starter. Bendix appears to be engaged as rocking doesn't move the car. Car moves in nuetral obviously. Starter fuse isn't blown, power to everything is fine. I assume I'm taking off the starter and looking at ring gear teeth/bendix?
10-03-2021, 10:04 PM | #2 |
Re: My first tow! Starter not cooperative
Common type of trouble when the bendix hangs up in the ring gear. I used to have that trouble and it would free up by pushing/rocking it in 4th but pushing the car towards reverse to make the enging turn backwards.
10-04-2021, 12:21 AM | #3 |
Turns out is was a partial ID 10T error. Removing the starter solved the problem, but my inability to rock it in gear was due to my Mitchel Overdrive cable shifter not being entirely in gear.
10-04-2021, 07:15 AM | #4 |
Check the starter and bendix out! MHO trying to start the A with the timing/ advance lever down cause/helps in the stuck bendix problem.
10-04-2021, 10:02 AM | #5 |
10-04-2021, 10:04 AM | #6 |
10-04-2021, 10:10 AM | #7 |
Ah so, thanks.
If you don't hear a rumor by 10 AM, start one!. Got my education out behind the barn! Last edited by katy; 10-04-2021 at 10:11 AM. Reason: Corrected typo |
10-04-2021, 03:04 PM | #8 |
I wish my A had a 4th. :-(
1921 Runabout 1930 Tudor Early 1930 AA Speed costs money. How fast do you want to go? |
10-04-2021, 04:28 PM | #9 |
Sorry was too modern, 3rd gear is sufficient.
10-04-2021, 05:06 PM | #10 |
