12-24-2012, 02:45 PM | #1 |
41 Ford Gauge Cluster
I would like to use the stock 41 gauge cluster to run with a 12 volt 350 Chevy engine.
What modifications do I need to do to the: a. water temperature b. oil pressure c. amp gauge d. fuel gauge and fuel sender Thanks for all the info and your time. |
12-24-2012, 02:55 PM | #2 |
Re: 41 Ford Gauge Cluster
you need a 12v to 6v voltage drop get the electronic one sold buy macs or epay,takes care of 3 gauges ,the amp gauge just needs the wire reversed or it will read backwards,you keep all your stock gauges and senders...
12-25-2012, 02:34 AM | #3 |
