Old 10-11-2021, 07:16 PM   #1
coolcoupe
coolcoupe's Avatar
Default hard start
Well I got a new problem. It starts after a little coaxing, take it for a 1/2 drive
runs fine, come back home, shut it off, it will not restart again until I crank it for 5 minutes!!. Any ideas ?
coolcoupe is offline   Reply With Quote
Old 10-11-2021, 09:45 PM   #2
tubman
tubman's Avatar
Default Re: hard start
I'd start with the coil and condenser. The fact that it gets worse as it heats up is indicative.
Old 10-12-2021, 08:10 AM   #3
oldskool
oldskool's Avatar
i had one like that gas was boiling in carb put a 1/2 insulator under carb problem solved
oldskool is offline   Reply With Quote
Old 10-12-2021, 12:02 PM   #4
Lawson Cox
Lawson Cox's Avatar
It ain't gonna heat up MUCH in 1/2 mile "drive". Coil/condenser likely problem,
notwithstanding.
You might also consider installing an electric fuel pump to prime the pump.
Old 10-12-2021, 04:59 PM   #5
tubman
tubman's Avatar
It don't take MUCH.
Old 10-12-2021, 06:11 PM   #6
coolcoupe
coolcoupe's Avatar
Sorry about the drive, I meant 1/2 hour drive. The dizzy is from Charlie, the coil is from Skip, condenser is from tubman. Where should I start ?? I do have a electric fuel pump for priming.
Old 10-12-2021, 07:09 PM   #7
petehoovie
petehoovie's Avatar
Condenser!
The only thing nice about being imperfect is the joy it brings to others....
"Silver rings, your butt! Them's washers!"
"We shot our way out of that town for a dollar's worth of steel holes!" - from 'The Wild Bunch' - 1969
https://www.youtube.com/watch?v=7NReUd2_0u0
Old 10-13-2021, 11:10 AM   #8
Mart
Mart's Avatar
Carb?
Faulty needle valve.
Punctured float.
High fuel level.
Power valve ruptured.
Power valve gasket not seating.
Power valve cracked.
Carb base and body joint failed causing vac leak into power valve chamber.
Quite a few things can make a 94 rich and will be a hard start when hot.
Does it fire quicker if foot held to floor while cranking?
Mart.
Old 10-13-2021, 11:37 AM   #9
Bill OH
I would try 5 or 6 gaskets under the carb. Does not sound like ignition with the parts you have installed. Try checking for quality of spark when trying to start. All of the connections clean and tight? If all of the foregoing fails try a stromberg 97 or 48. They gaskets solved my hard start, but I also blocked the heat riser - mine is a fair weather setup. Mart’s suggestion of flooring the accelerator when trying to hot start is good - that will point you in the right direction.
Bill OH is offline   Reply With Quote
