Old 07-13-2017, 05:26 AM   #1
31 RPU
Default Horn Problem
My horn blows just fine with car running or off. When I turn the lights on or hit the brake it just growls. Do I have a problem with my generator?
31 RPU is offline   Reply With Quote
Old 07-13-2017, 06:20 AM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Horn Problem
No, all sounds normal for a charging system with no voltage regulator. The lights or brake light draws more power than the generator may be set for, and they will then draw a bit of the power from the battery, thus due to line loss, the horn has a bit less voltage available.
If the horn sounds good now, I'd leave it alone, otherwise you could try one click looser on the horn adjustment screw.
Old 07-13-2017, 06:56 AM   #3
marty in Ohio
marty in Ohio's Avatar
What Tom says, also make sure the horn is lubricated.
Marty
marty in Ohio is offline   Reply With Quote
Old 07-13-2017, 09:46 AM   #4
Will N
Will N's Avatar
...And the commutator is nice and clean!
Will N is offline   Reply With Quote
Old 07-13-2017, 10:25 AM   #5
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
The best "FIX" for horn problems is a 6 Volt, positive ground ALTERNATOR! You'll never be SORRY you did it!
Bill Beep
"THE ASSISTANT GURU OF STUFF"
Old 07-13-2017, 05:02 PM   #6
31 RPU
I have adjusted the horn and lubricated it.
I have an alternator that is in a generator case. You can't tell it is an alternator.
I may put it on and try it.
Old 07-13-2017, 11:18 PM   #7
Mike V. Florida
Mike V. Florida's Avatar
Well that a horse of a different color. If you have an alternator it should already have a regulator.
When you blow your horn what does the ammeter read?
With the lights on and the horn blowing what does the ammeter read?
Old 07-13-2017, 11:52 PM   #8
31 RPU
It shows discharging the needle goes to the left
Old 07-14-2017, 07:56 AM   #9
SeaSlugs
SeaSlugs's Avatar
How bright are your lights? if the horn blows fine with the car off (lowest possible voltage) id suspect grounding issues and or the headlights/brake lights are somehow grounding thru the horn wiring.
Are your battery terminals clean and tight? Does the car crank over quickly or or is it kinda sick sounding?
Somewhere I think you have a corroded/rusted/loose connection as the connection is good enough to power one thing but overload it and it cant get enough juice through.Check your ammeter and junction box wiring as well.
are your horn wires under the tabs from the sides?
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 07-14-2017, 10:57 AM   #10
rocket1
Install a relay in the horn cover,with direct battery voltage.
rocket1 is offline   Reply With Quote
Old 07-14-2017, 02:44 PM   #11
Jacksonlll
Jacksonlll's Avatar
Send a message via ICQ to Jacksonlll
Try this. Back off on the adjuster screw until there is no sound. Then hit the button and let horn motor spin up for about 30 sec to a minute. The little motor likes to run. Let it run and it will sound better after you readjust it.
Jacksonlll is offline   Reply With Quote
Old 07-14-2017, 03:01 PM   #12
marty in Ohio
Jackson,
Now that's a new one on me!! My horn's fine, but I might try this just for the heck of it. I guess it couldn't hurt.
Marty
Old 07-14-2017, 04:07 PM   #13
31 RPU
I did let the motor run like you said and oiled it to make sure everything was good and loose. Of course I noticed the horn doing this after I turned on the lights because it was getting dark outside. Otherwise I may not have noticed the problem.
Old 07-14-2017, 04:11 PM   #14
31 RPU
Battery terminals look fine. Ground cable doesn't look really good but I do have a new ground cable I will put on. The headlights are pretty bright. Car cranks over pretty good for a 6volt.
I will have to check other connections.
Thanks
Old 07-14-2017, 05:25 PM   #15
SeaSlugs
SeaSlugs's Avatar
as a test for an iffy ground cable use a stout jumper cable from the ground terminal off the battery to the frame somewhere that is very clean. the temp added ground may do wonders.
Old 07-14-2017, 08:45 PM   #16
Dutie
Dutie's Avatar
Im with Sea Slugs....X 2
Dutie is offline   Reply With Quote
Old 07-15-2017, 10:53 AM   #17
katy
katy's Avatar
You might try moving the horn wire from the generator terminal over to the starter stud.
Thread Tools
Display Modes
