Old 10-18-2014, 03:10 PM   #1
mark180
mark180's Avatar
Default tire irons
This is a bit of a noob question. Are there types of tire irons that are better than others? I haven't had to change a tube type tire since I was a kid. I don't want to get irons that will mess up my rims.
mark180 is offline   Reply With Quote
Old 10-18-2014, 03:51 PM   #2
Ralph Moore
Ralph Moore's Avatar
Default Re: tire irons
I use a pair of motorcycle irons, they are smooth and slightly curved, designed to be used with tubes , unlike some car tire irons.
Ralph Moore is offline   Reply With Quote
Old 10-18-2014, 04:41 PM   #3
cmbrucew
cmbrucew's Avatar
X2 on the bike irons.
Use emory paper to smooth them if the are new.
Bruce
Works good
Lasts long time
cmbrucew is offline   Reply With Quote
Old 10-18-2014, 06:34 PM   #4
russcc
Ken's Tools make the best tire irons. They have a curved dip at the end that makes changing tires simple with irons. Mohawk Rubber Company in Hingham MA is one dealer that I know that carries them, as that's where I got mine.
russcc is offline   Reply With Quote
Old 10-19-2014, 10:35 AM   #5
rotorwrench
rotorwrench's Avatar
I took my hand operated held belt sander and put my own curve into some spoons I purchased from a Snap-On dealer, I then polished them up and they work slick.
Old 10-19-2014, 01:07 PM   #6
Pete
Pete's Avatar
All this brings to mind a slightly humorous story about a friend that was USAC national midget champion in 1954.
He was racing on a very limited budget as many were in those days. They sometimes raced 4 times a week and on both dirt and pavement. He could only afford one set of wheels so had to change tires each time they went to a different surface track. Believe it or not, several times I saw him change 4 wheels from slicks to dirt tires in 20 minutes with nothing but 2 big screw drivers and a ball peen hammer. Needless to say, the mag wheels didn't look too good after a 50 race season but they got the job done.
Old 10-21-2014, 07:00 AM   #7
38Tudor
38Tudor's Avatar
I think the curved spoon type is best for tube tires.
"Thrifty Sixty"
Ford V8 for 1938
38Tudor is offline   Reply With Quote
Old 10-21-2014, 11:58 AM   #8
A bones
A bones's Avatar
Harbor Freight for the money. Enjoy yer day, Tom
A bones is offline   Reply With Quote
Old 10-21-2014, 03:11 PM   #9
A bones
A bones's Avatar
Worth mentioning, do not lube with soap. It helps create rim rust at the bead. Last time I did a set (on the ground) I tried WD40. It went well. Some like talc for slipperiness, another suggestion seen here on this forum, I forget who, is to use plastic trash bag. Sounds slick, Just pull it out when done.
Enjoy yer day. Tom
Hate can't fix what it started.
Old 10-21-2014, 03:22 PM   #10
Bruce Lancaster
Gemplers has a really good range of tire tools, all sorts of irons, a neat bead breaker, and consideration of tubes because their customers are dealing with all sorts of agricultural and trailer tires, not just late model cars: http://www.gemplers.com/tires-supplies
Bruce Lancaster is offline   Reply With Quote
Old 10-21-2014, 04:01 PM   #11
corvette8n
corvette8n's Avatar
I bought a 30" spoon type from Tractor supply, I use them to mount the 11.2x28 tires on my tractor, also have done several car tires with them.
Old 10-21-2014, 08:06 PM   #12
cmbrucew
cmbrucew's Avatar
If you are looking for full sized tire irons Firestone made some good ones.
Most tire men have their own favorites. Hammers as well for breaking beads.
Bruce
Works good
Lasts long time
Old 10-21-2014, 09:56 PM   #13
38Tudor
38Tudor's Avatar
I am a professional tire guy and I use soap. The whole tire industry uses some form of soap. Good luck. Work a curved spoon bar carefully and you won't mess up your rim.
"Thrifty Sixty"
Ford V8 for 1938
Old 10-22-2014, 03:06 AM   #14
A bones
A bones's Avatar
HI 38Tudor. Me too lots of tires. Worn out a couple of Coates machines. Started with a Bishman. When that broke had to use the floor with a hand breaker, then irons 'til we could buy a new one(new tires cost $12). I have a jug of Ru-glyde in the garage now. I just get tired of seeing steel rims that won't hold air because of rust pits. Tired of grinding, sanding, chopping rust. Then gluing the beads, to get a seal.
Enjoy yer day. Tom
Old 10-22-2014, 06:40 AM   #15
Walt Dupont--Me.
Walt Dupont--Me.'s Avatar
That reminds me when me and my friend both in our teens, his father had a 40 Ford pickup, he was changing a rear tire, he left a tire iron inside the rim, when't down rod a little ways, BANG, the tire iron poked a hole right through the rear fender. Walt
Walt Dupont--Me. is offline   Reply With Quote
Old 10-22-2014, 09:07 AM   #16
Bruce Lancaster
An ancient issue of Life Magazine I looked at, I think a wartime issue, had a big picture of items that had been found in flat tires...I could identify a number of Ford parts in the spread!
Old 10-22-2014, 11:51 AM   #17
A bones
A bones's Avatar
My personal favorite was a nine inch sawzall blade. But back in the day, those left over tires from the second war would give it up to sharp stones and tree twig fork joints.
Enjoy yer day. Tom
Old 10-22-2014, 12:15 PM   #18
Ralph Moore
When I was in the army, we would get quite a few rifle cartridges shoved in tires, mostly when out on maneuvers.
