Old 09-25-2021, 07:44 AM   #1
Shoovel
Shoovel's Avatar
Default Looking at 63 Galaxie
Folks,
I’m looking at a 63 Galaxie 2 door with a 390 & 4 speed. Is there anything on these models I should look out for? Any weak points for rust etc?
Thanks
Shoovel is offline   Reply With Quote
Old 09-25-2021, 08:01 AM   #2
KULTULZ
KULTULZ's Avatar
Post Re: Looking at 63 Galaxie
You say 1963. The 1963 had a BOX TOP (2DR). The 1963 1/2 had a FAST BACK (2DR).
As for jungle rot, the usual places, floor pans, rocker, lower door skin, quarters, trunk pan and lower front fender. Take a small magnet with you to find any bondo.
It would be best to put it on a lift to check for any damage and/or rust maggots.
What area is the car located in?
- WHY IS IT ... -
... that everything you buy in the grocery store is either wrapped in or contained in plastic but the government doesn't want you to carry it out in a plastic bag?
WONDERING IN W(BY GOD)V ...
DIAGNOSED CDO - (OCD In Correct Alphabetical Order)
KULTULZ is offline   Reply With Quote
Old 09-25-2021, 08:56 AM   #3
rotorwrench
rotorwrench's Avatar
Default Re: Looking at 63 Galaxie
All fords will rust down in the low entrapment areas. It takes X-ray vision to tell what has been done to any old car over the years. I have a life long fondness for the 1963 Galaxie models. They were natural born race cars and the Galaxie 500 XL 2-dr fast back hard top that came out in mid production is a hell of a car but the box tops were every bit as good in function.
A friend of mine had a 4-dr that he tried to kill several times but was only moderately successful. He damaged a 9-inch rear axle after the 390 went in and he traded a T85 R11 overdrive transmission for a super T-10 4-speed. I was with him several times when he took some S-turn dirt roads at 80 MPH. That car really hugged the road well. He eventually went on to a 1964 Galaxie 500 XL fast back but he swore it wasn't quite the same as that old 63.
Old 09-26-2021, 08:07 PM   #4
Shoovel
Shoovel's Avatar
I was hoping someone could decode this Canadian VIN. I have, I think, just want to confirm.
PAINT: IBB. TRIM: 614. ENGINE: CA
SERIAL# 523821 662B 63L
Thanks
Tom
Old 09-27-2021, 10:58 AM   #5
rotorwrench
This link looks good. http://www.mercurystuff.com/1963-gal...-canadian.html
As far as I can tell, the 1BB is defined as 1= single color overall and BB= Raven Black.
The 614 is a red color trim. CA is for 223 6-cylinder. The serial is the linear number. For 662B the 6= 6-cylinder and 62B is for Galaxie 2-door sedan body type. 63 is the year and L is for left hand drive.
Old 09-27-2021, 12:46 PM   #6
Shoovel
Shoovel's Avatar
Thanks,
That’s what I got as well.
Old 10-05-2021, 01:33 PM   #7
bobss396
bobss396's Avatar
The rockers may have been galvanized by 1963. Usual spots were the lower front fender rear lower quarters and rear bumpers and of course the floors in areas that use road salt.
bobss396 is offline   Reply With Quote
Old 10-05-2021, 09:07 PM   #8
mercman from oz
mercman from oz's Avatar
Cover of the Canadian Sales Brochure for the 1963 Fords.
