02-07-2020, 07:26 PM | #21 |
Re: Wide 5 Artillery Wheels
i had no end of trouble trying to find someone that could balance wide 5s Ended up using 2mm beads was skeptical to start with but they work and i can rotate tyres with no need to re balance.
02-08-2020, 01:29 AM | #22 |
If I can't find a hub to sacrifice, I may try the bead thing, or the speedway adapter. Thanks tubman and duce lover
02-08-2020, 02:30 AM | #23 |
If you did find a hub the spindle of the machine would have to fit thru the hole even if you removed the bearing races.
02-08-2020, 04:27 AM | #24 |
one of the nicest things about converting the wheel bolt pattern to 3 on 4 1/2 is : billions of inexpensive wheels.
02-08-2020, 06:04 AM | #25 |
That looks like a very nice wheel, with bonus Chrome Trim Ring. |
02-08-2020, 06:13 AM | #26 |
John McArthur, well know Early Ford V8 enthusiast from Australia makes these Wide Five Wheel Balancing Discs. If interested, you can email him on the above address. |
