12-31-2018, 10:26 AM | #1 |
Intake Manifold Question
I would like to put dual carbs on my project and am getting to the point of needing an intake manifold. I have not been able to determine if there is a vacuum port on the aftermarket units on the driver side that connects with the distributor.
Does anyone here have a dual set up with the vacuum port? I'm assuming that I need to have this connected. Below are two links to what I'm looking for but there's no mention or any pictures of the vacuum port. Also, one of them is not advertised for my year (1937 block) and I'm not sure of the difference. https://www.speedwaymotors.com/Speed...y=91015985-PLN https://www.speedwaymotors.com/Offen...ifold,794.html Thanks for any info and 'yes' I am aware that there's no real advantage to dual carbs Tim |
12-31-2018, 10:56 AM | #2 |
Re: Intake Manifold Question
The Edelbrock Slingshot is equipped with two vacuum ports, one for the distributor advance and one for the wipers. It’s pricier than the two you’ve listed, but it’s well worth it. Also, it should fit your ‘37 block as it works great on my ‘36 21 stud. I did have it polished before being installed.
https://www.speedwaymotors.com/Edelb...CABEgKj1_D_BwE |
12-31-2018, 11:58 AM | #3 |
Early ford distributors used manifold vacuum, so it should be easy to add a port if there are none. I find it hard to believe that anyone made a manifold without a vacuum port, but they may exist. If there is only one port "tees", are available that make it easy to connect both the wiper and the distributor. With a little thought and some simple hand tools, it should be easy to add a port to an aluminum manifold if need be.
12-31-2018, 02:53 PM | #4 |
My Offy manifold is the same style as your link with the '32-'48 manifold. It has a port just under the rear carb (on the drivers side) that can be used for vacuum for the early style vacuum brake distributor.
01-01-2019, 02:16 AM | #5 |
Southwind heaters used a spacer plate with a manifold vacuum port. There is one for sale on ebay right now. You probably would need two to get the carbs sitting level with each other.
https://www.ebay.com/itm/South-Wind-...frcectupt=true Last edited by Flathead Fever; 01-01-2019 at 02:27 AM. |
01-01-2019, 02:23 AM | #6 |
01-01-2019, 07:26 AM | #7 |
I don’t mean to take the thread of the rails but,.....isn’t that a racey ad for back in the day?...Mark
01-01-2019, 09:45 AM | #8 |
I was thinking the same thing!
I don't mind drilling and tapping a hole for the vacuum port as someone suggested above so guess I'll go that route. Having spent several hours of searching online, I can't seem to find out any definitive reason why some intakes are designated for later years and some for early. I have a 37 block and the link below is the one I would like to purchase. Can anyone tell me why I shouldn't buy it? https://www.ebay.com/itm/1949-53-Fla...53.m1438.l2649 The price is right. The carbs are more centered than some instead of rearward mounting. I also am using a 12V alternator and not a generator. |
01-01-2019, 10:34 AM | #9 | |
https://www.jalopyjournal.com/forum/...rences.442152/ |
01-01-2019, 10:35 AM | #10 | |
The early '32-'48 engines sit level in the torque-tube chassis, so the carb base is also level. Ventilation enters the rear of the intake (fuel pump stand) and exits down the front, under the intake, and out the pan, starting in '35. The late '49-'53 engines sit at an angle because of the new open drive lines and hypoid rear ends, which requires an angled carb base to level the carb. Ventilation enters toward the front of the intake, along with the oil fill. Fumes exit through a road draft tube out of the front of the intake. Look carefully at early and late manifolds, as they will bolt to all flathead engines, but carb angles and engine ventilation are two issues that need to be considered. There are some aftermarket intakes that may vary from the norm, like the Navarro tripple I use that has level carb bases but has the late oil fill and road draft provisions at the front. |
01-01-2019, 10:56 AM | #11 |
Bob, that explains the differences between pre-48 and the 8BA types, but I have noticed that some of the manufacturers list different manifolds for '32-'41 and '42 - '48 engines. Can you explain that difference?
01-01-2019, 11:15 AM | #12 | |
'48 and earlier let the fumes find their own way out thru an opening in the left front of the pan and the breather cap on the fuel pump stand. The blocks are a bit different for each system. Fuel pump push rod lengths also vary. |
01-01-2019, 11:22 AM | #13 | |
Off hand I don't know for sure, but my guess would be slight generator mount and/or fuel pump stand differences. |
01-01-2019, 11:33 AM | #14 | |
Thanks Bob. This is what I needed to read. |
01-01-2019, 06:42 PM | #15 | |
The intakes listed for '32-'41 do not have a generator mount. The '42-'48 intakes are more versatal, having a generator mount. |
