Old 01-13-2022, 11:22 AM   #1
klrh20frank
Default getting transmission in neutral when out of car
i have the engine and transmission ready to install and decided to put the transmission in neutral before installing the engine/transmission as a unit. i thought it would be easier to stab the ujoint.
The book says put the sliding gears in the neutral position. Where are the sliding gears to be located. A picture would help.
Thanks
klrh20frank is offline   Reply With Quote
Old 01-13-2022, 11:44 AM   #2
Gary WA
Gary WA's Avatar
Default Re: getting transmission in neutral when out of car
In Transmission below shifting lever
www.whidbeymodelaclub.com
Old 01-13-2022, 12:20 PM   #3
klrh20frank
https://www.fordbarn.com/forum/attac...1&d=1642094282
this is where the gears are now.
Hope this works.
Old 01-13-2022, 12:48 PM   #4
goodcar
Replace the tower and engage the clutch. Once it is neutral block the gears from meshing with a piece of wood or Styrofoam.
goodcar is offline   Reply With Quote
Old 01-13-2022, 05:26 PM   #5
Reds34
I think the 2nd and 3rd gear needs to move forward a touch?
Red
Reds34 is offline   Reply With Quote
Old 01-14-2022, 06:45 AM   #6
Rodrelic
Grab the joint and spin it
Rodrelic is offline   Reply With Quote
Old 01-14-2022, 08:02 AM   #7
rotorwrench
rotorwrench's Avatar
The 2nd/high gear is either meshing with the cluster gear, meshing with the dogs on the input shaft, or somewhere in between. In between is neutral. The 1st/reverse gear needs to be between its corresponding cluster gear and the reverse idler to be in neutral. The two sliding gears mentioned have the grooves that the forks ride in. With tower in neutral, the forks should slide right in to those grooves.
Old 01-14-2022, 06:11 PM   #8
Russell Reay
Hold the tower and shifter so you can see the sliding forks well. Play with the shifter so you can see how the forks move into all four positions and neutral. Slide the gears around in the transmission with your fingers to see how they move. When you can move the shifter forks to the correct neutral position, slide the transmission gears around so the grooves adjacent to the gears match the position of the forks on the tower. Drop the tower down, screw in two cover bolts and confirm that the parts are properly aligned. When I disassembled my car I considered taking multiple photos or engaging in creative ways to keep the gears from moving. I finally decided that this wasn't rocket science, and the worst that could happen is that I might need to try reinstalling the tower several times. I did just as described above, and the forks slid into place perfectly the first time.
Russell Reay is offline   Reply With Quote
Old 01-14-2022, 07:26 PM   #9
Russ/40
Russ/40's Avatar
Extremely well articulated !
Russ/40 is offline   Reply With Quote
Old 01-16-2022, 05:55 PM   #10
aandtman
Here is what I made, especially handy when installing body.
aandtman is offline   Reply With Quote
Old 01-17-2022, 10:50 AM   #11
klrh20frank
Thanks for all the suggestions. i had the engine/Transmission out and was able to slide the gears around easily until i coud turn the ujoint. The suggestions all helped. thanks for the help.
