02-01-2015, 09:32 AM | #1 |
Trailer tie-down discussion
I'm interested in optimum or preferred methods for tying down my vehicle on a flatbed trailer. I've searched this forum and found discussions pro and con on open (flatbed) and enclosed trailers. I see options for securing the axles fore and aft of the vehicle to control forward and rearward movement, I also read one thread on this forum that talks about crossing the straps to control lateral movement. I've rented the U-Haul flatbed trailer that had straps over both front tires. Then I have read that tire straps should be used on all four tires. I guess that would address the lateral loading.
For my specific application, chose an Aluma flatbed trailer. I won't be concerned about long distance travel requiring protection from weather and so that I could use the F150 as a routine driver rather than a heavier duty truck. I bought the trailer to haul my truck for show and tell, meets, local events and possibly events up to 8 hours away. I'm not sure that I want to install the track with re-locatable tie down clip location, but considered that as I will haul potentially either of two vehicles (vintage Mustang) as well as the truck. The trailer came with four D-ring tie downs. The trailer was specifically designed for the use I intend; electric brakes on two axles, weight capacities, etc, so I would like to focus on tie down methods. |
02-01-2015, 09:40 AM | #2 |
Re: Trailer tie-down discussion
I hauled my car back to Mississippi from Florida on one of the U-Haul aluminum trailers with the straps over the front wheels. You have used the same. I can't imagine anything being any better or easier than that setup. If I ever get a flatbed trailer I would mimic that system in it's entirety.
02-01-2015, 10:11 AM | #3 |
I tow cars quite often on my flatbed trailer, sometimes on very long trips. I connect four straps, two to front axels and two to rear axels, with both front and rear straps crossed. On long distance trips I also attach a safety chain to both front and rear, from center of axels to front and rear of trailer. On some occasions I will also have wheel chocks at all wheels both front and back. I guess I am a belt and suspenders type of person when I am towing a vehicle on a trailer. I figure better safe than sorry.
02-01-2015, 11:00 AM | #4 |
Cross strapping is not recommended because if something happens to one strap the remaining strap is not doing much to control the vehicle.Overkill method would involve both straight and cross strapping on bothe ends.Most important is to use good quality straps and have a secure attachment to the trailor.Phil
02-01-2015, 11:09 AM | #5 |
When I got my '50, I rented a u-haul and used the front tire straps and a heavy strap on the rear axle. I trailered it 700 miles at highway speeds...no problems.
Gene |
02-01-2015, 11:31 AM | #6 |
I am not a big fan of most tie down straps, unless they are rated at over 10,000 lbs and are designed to tie down vehicles. I prefer the J hooks with 3/8" chain X'd on the rear axle attached to D rings welded and/or bolted to the trailer frame. I always use two 3/8" chains on the front of the vehicle, securely attached to the chassis and to D rings on the trailer frame. To secure the front and rear chains I use medium duty binders, the kind that attach to the loose ends of the chains, then tighten by pulling the handle to take up slack. As a safety feature I put a safety wire through the binder handle, to the binder assembly. I learned many years ago that the tow vehicle has to be up to the task it is being asked to do. The average 1/2 ton is rated for a max load of 5,700/6,000 lb's.. Some heavy half tons, F150 etc., are rated to carry more. When you factor in the weight of the tow vehicle, 4,000 # plus, a trailer at 2,k and a 4k vehicle, without realizing it you have over 10k rolling down the road being pulled by a vehicle designed to carry maybe 6/8k... A standard 3/4 ton, F250.C20, is usually rated to gross 8,5k My tow vehicle since 2001 is a Super Duty Ford F350 7.3 diesel, it currently has 164k on the odometer.. I may sound paranoid about my towing practices, I can only say that I have never had a wreck, nor have I ever lost a load..
Bill.... 36 5 win cpe |
02-01-2015, 12:15 PM | #7 |
I have been a transporter for 30 years with almost 3 million accident free transport miles. For strapping down a vehicle you will want to use good quality ratchet straps & over the axle short straps. CROSS strapping is the ONLY proper way to tie down a vehicle. The straps will not break unless you are using junk or warn out ones. If you do not cross the straps the vehicle can move side to side. 2 crossed straps in the front & 2 cross straps in the rear & I also keep my winch cable on as well for safety. You do not want to use chains on a nice vehicle as they will scratch the paint on the suspension/axle/frame, etc..
You will see lots of opinions but cross strapping is absolutely the safest way to secure your vehicle. In some states it is the law.
Your QUALITY Ford Barn Transporter- Open or Enclosed. Bill's Auto Works Est. 1983 & Still Going Strong! 1955 Chevy Altered W.B. Gasser 1955 Nash Amb. Cust. Lemans 1957 Pontiac Chieftain 2 DR HT 1964 Pontiac Grand Prix 2 DR HT 1966 Pontiac Catalina Conv 1966 AMC Ambassador DPL 2 DR HT 1966 AMC Ambassador Cust 2DR HT 1967 AMC Marlin 1967 Toronado 1973 Chevy Nova Full Chassis Car 1992 Jag XJS Conv 1992 Jag XJS 2 DR Coupe 2007 Cadillac XLR-V Supercharged Roadster |
02-01-2015, 12:28 PM | #8 |
I am "belt and suspenders" like John M ... have e-track on the trailer floor and use MACS https://www.macscustomtiedowns.com/ high quality straps. These straps secure front and rear axles with vertical pull down at each corner pulling straight down - then I also cross tie front and rear - super secure and gives be piece of mind.
02-01-2015, 12:40 PM | #9 |
I use specific short tie down straps, two in the front and two in the rear. I see no advantage to cross strapping unless you were using a strap long enough to allow side to side movement. Guess it wouldn't hurt, but would require a longer strap than I would want to use. Set them tight enough to not allow the car to bounce or move. The trailer I prefer to use has channels for each wheel, to me much better than a flat bed. I have several trailers and much prefer the channel style.
02-01-2015, 01:38 PM | #10 |
Going is one thing, Make sure the vehicle and the trailer have proper braking ability or there will be a problem when you have to stop quick!
02-01-2015, 01:47 PM | #11 |
What are the thoughts on the tire straps? They would seem to hold lateral loads.
My concern strapping the axles would be damaging brake lines or other undercarriage parts. I just looked at the '41 and I would not interfere with brake lines when I strapped to the axles, either front or rear. The brake lines on the newer car (1967 - non-flathead) has brake lines running just behind the top surface of the rear axle. |
02-01-2015, 02:30 PM | #12 | |
I'm inclined to go with the Ford limits, but am very interested in knowing from others experience if this is not a safe load. I towed the '41 home on a U-Haul flatbed connected to my 06 Suburban and didn't seem to have any trouble. I wasn't traversing mountains though. I'm thinking the F150 should do a better job. |
02-01-2015, 02:53 PM | #13 |
That combination will tow safely with out any issues, mountains or not. Here is a picture of a half ton with the towing package & an aluminum Featherlite trailer. This combination has 604,000 miles on it mostly towing with never an issue.
Also, your concern about the brake lines...nylon straps will not hurt the brake lines. I have found that if the line is up off the axle a little, I slide the strap under the line, if not I go right over it. There is nothing wrong with wheel straps though, it is more a personal preference & having properly located mounts on the trailer. Also, GVWR on a truck is NOT intended to include the weight of something you are towing. This rating is strictly for the weight of the truck & what you load in it.
Your QUALITY Ford Barn Transporter- Open or Enclosed. Bill's Auto Works Est. 1983 & Still Going Strong! 1955 Chevy Altered W.B. Gasser 1955 Nash Amb. Cust. Lemans 1957 Pontiac Chieftain 2 DR HT 1964 Pontiac Grand Prix 2 DR HT 1966 Pontiac Catalina Conv 1966 AMC Ambassador DPL 2 DR HT 1966 AMC Ambassador Cust 2DR HT 1967 AMC Marlin 1967 Toronado 1973 Chevy Nova Full Chassis Car 1992 Jag XJS Conv 1992 Jag XJS 2 DR Coupe 2007 Cadillac XLR-V Supercharged Roadster Last edited by Bill's Auto Works; 02-01-2015 at 03:01 PM. |
02-01-2015, 03:28 PM | #14 | |
I do not cross tie but do use FOUR high quality straps. It is very important to pull down the sprung weight of the vehicle as much as possible. professionals know this and do it always. You want to minimize the ability of the towed vehicle to bounce. in other words, tie it down above the springs. Also, as a previous poster has mentioned, the tow vehicle, trailer, etc. MUST be "right" as well. We've all seen too much tongue weight and too little. Some of the vehicles I've seen towing make me wonder how the idiot driving ever got a license. Of course, i wonder this while I am increasing the space between he and I. Not long ago I witnessed a guy pulling a trailer with a modern Silverado pick-up loaded on the trailer. Only two straps, both on the left side while he's going 65mph+ down the freeway. The towed vehicle was bouncing all over the place on that trailer. I wondered how far he got until it came off... Makes me a firm believer that in order to obtain a drivers license there should be a minimum IQ required. If so, there would be a LOT less traffic...
02-01-2015, 03:53 PM | #15 | |
02-01-2015, 08:08 PM | #16 |
I tow a 20 foot enclosed trailer and 35 pick up with a F150 rated at pulling a 9400 lb. Trailer, no problems yet. I also pull horse trailers and a 8200 lb. Travel trailer. I use the wheel style straps on 4 wheels of my 35 when in the enclosed trailer, they are easy to use.
02-01-2015, 08:27 PM | #17 |
I got forced off the road one time down a deep ravine.
Cross strapping, plus tire straps, and a tight winch cable kept the car on the trailer with no damage. |
02-02-2015, 04:23 AM | #18 | |
To answer your question
If you do not want to install e-trac and use the d-rings supplied with the trailer then get some axle straps and ratcheting soft tie straps from Summit Racing or a comparable source ... Depending on the location of your d-rings relative to the vehicle position on the trailer & the attachment points you choose - you can decide which direction to run the straps and whether or not to cross them. Fasten at (4) points to the axle and/or frame and you are set to go. Check your straps after a few miles of driving & re-tighten as required. Jim |
02-02-2015, 06:28 AM | #19 |
I cross strap to the axles to welded Drings so that front straps pull forward and rear straps pull rearward. I bought the heaviest car strabs Northern had and have never had a problem. I also strap to the axles with not problem of bounch. Have pulled a Model T to MN,VT and lots of other places from TN. I too have been hauling heavy equipment, farm equipment, logs and other loads for many years.
02-02-2015, 11:52 AM | #20 |
Thanks guys. I see some variance of recommendations here, but I hope this thread becomes searchable for the next guy with this question.
Meanwhile, I am comfortable with the four tie-down locations on my trailer and have my question sufficiently answered. |
