08-29-2014, 08:25 AM | #1 |
Oil Pan Dipstick Tube Boss
Good morning Barners,
Ok, one of the main reasons I removed the oil pan on my 47 (besides to replace the gaskets), was because the threads in the boss where the by-pass filter return line screws in are stripped. I know that Bob Drake is the main source for them, but they are back ordered and apparently they must be looking for someone else to reproduce them at this time. I've called everyone else who listed them but to no luck because no one has any. So, short of cutting new larger threads in mine, I was wondering what anyone else has done in the past that may have ran into this problem. Thanks in advance for your replies!! Kevin
"Failure is simply the opportunity to begin again, this time more intelligently". Henry Ford. |
08-29-2014, 08:35 AM | #2 |
Re: Oil Pan Dipstick Tube Boss
Have you tried Joblot in NY, they may have NOS originals
08-29-2014, 09:07 AM | #3 |
Hello Kurt,
Yeah, I called them this morning, and they have none either. Seems that they all (Dennis Carpenter, Joblot, C&G, etc.), all get them from Bob Drake and non of the vendors have any. Kevin
08-29-2014, 09:29 AM | #4 |
There are other options for attaching the oil filter return line. Some oil pans had a separate threaded female fitting attached to the side of the bulk head. There were also through drilled and threaded bolts at the fuel pump stand used for the return.
If you can't find a dip stick fitting with the return oil line, I have a new or possibly a good used one in my stash of stuff.
08-29-2014, 09:54 AM | #5 |
Hello Kevin. Here are a couple more recommendations to check:Baxter Ford Parts (785) 842-9256 and Little Dearborn Ford Parts (612) 331-2066. Both are very nice folks to deal with. Hope you find the part. Steve
If it aint broke, don't fix it! |
08-29-2014, 10:02 AM | #6 |
08-29-2014, 12:03 PM | #7 |
Heli-coil it. I did one that way.
08-29-2014, 06:49 PM | #8 |
Thanks everyone! Thanks Steve!!
John, PM sent. Kevin
08-29-2014, 08:58 PM | #9 |
Found one in my stash. Threads for tube and fitting are good. Do you have the brass fitting?
John "Never give up on what you really want to do. The person with big dreams is more powerful than one with all the facts". Albert Einstein Last edited by JM 35 Sedan; 08-29-2014 at 09:10 PM. |
08-29-2014, 09:48 PM | #10 |
John,
No, I don't have the brass fitting. Someone in the past has about a 2" long hex looking fitting that threads into the boss, then the oil line threads into it. Kevin
