Old 10-14-2019, 07:02 AM   #1
john_gto
Default Hub puller question
Bought this hub puller at Hershey - it has the raised letters "Ford AB Pat no. 1867211 " on it . I have searched the A and T forums as well as the web finding only 1 photo of a similar one which suggested it was for a T.
Does anyone know what this one is or made for ? It does fit the A rear hub .
Thank you
John
john_gto is offline   Reply With Quote
Old 10-14-2019, 07:10 AM   #2
chap52
chap52's Avatar
Default Re: Hub puller question
Pretty cool looking tool... Chap
chap52 is offline   Reply With Quote
Old 10-14-2019, 07:50 AM   #3
alexiskai
alexiskai's Avatar
The patent number you posted doesn't correspond to any similar device, but if at least the first 4 digits are correct, that would mean this device was patented around 1928-1930 – suggesting it's meant for a Model A.
Old 10-14-2019, 07:52 AM   #4
John
John's Avatar
I believe it will work on the '26-'27 Model T wire wheel hubs and on the early Model A hubs with the raised ribs.
John is offline   Reply With Quote
Old 10-14-2019, 08:48 AM   #5
john_gto
Thanks for the comments so far - the patent numbers are difficult to read - the 8 could be a 3 and the last two 11 could be 77. I checked on a spare axle and hub and the thick lip at the bottom does fit nicely in the A hub groove. Trying to determine if it was made to be used on model A before using it on our 31 SWTS
Old 10-14-2019, 09:40 AM   #6
Joe K
Joe K's Avatar
With the generous thread on the thumb-nut, it may work on either the "raised ridge" version hub AND the groove style.
Joe K
Shudda kept the horse.
Joe K is offline   Reply With Quote
Old 10-14-2019, 10:17 AM   #7
alexiskai
alexiskai's Avatar
Those numbers didn't turn up anything. You can run the search yourself here, just enter the number with a 0 in front of it ("01867211"):
http://patft.uspto.gov/netahtml/PTO/patimg.htm
Old 10-14-2019, 11:10 AM   #8
Dan Partain
Dan Partain's Avatar
I have one of those, it works great on my A's, check out the box.
-DAN
Dan Partain is offline   Reply With Quote
Old 10-14-2019, 12:07 PM   #9
Redbird
Redbird's Avatar
Pretty cool item!
Redbird is offline   Reply With Quote
Old 10-14-2019, 12:34 PM   #10
john_gto
Thank you all ! Dan -nice to see the box it came in and the instructions. At $20 it looks like this was a good deal .
Old 10-14-2019, 12:48 PM   #11
john_gto
This puller was made by "Duro Metal Products Co" Chicago Il.
Patent 1,857,211. Applied for Feb 27 ,1931 and granted May 10,1932
Old 10-14-2019, 01:35 PM   #12
alexiskai
alexiskai's Avatar
The "Ford AB" lettering must mean "works with the Ford Model A or B." The B would have been out at the time the puller was manufactured.
Old 10-14-2019, 06:41 PM   #13
john_gto
That is likely so - Dan's puller has "Ford A" and "Pat Pend" from what I can see.
Thanks again everyone for your help!
John
Old 10-14-2019, 06:49 PM   #14
john_gto
Patent drawing
