Old 11-05-2015, 10:00 AM   #1
37 truck
Default Door Alignment
I think this would apply to all our old Fords. In my case I am trying to align the doors on a 37 pickup. They both sag so that the door latch and dovetail don't line up. They are low about a quarter inch. The hinges are not worn and are tight. Can I heat the lower hinge and bend it back to raise the door, or is shimming the hinge the only way?
37 truck is offline   Reply With Quote
Old 11-05-2015, 10:45 AM   #2
Binx
Default Re: Door Alignment
The structure behind the doors' lower hinge may be the culprit. Check out this site...
http://www.jefflilly.com/fabrication/36-door-fit/
Lonnie
Binx is offline   Reply With Quote
Old 11-06-2015, 10:03 AM   #3
41PICUP
41PICUP's Avatar
Very informative article, thanks.
41PICUP is offline   Reply With Quote
Old 11-06-2015, 10:15 AM   #4
37 truck
Great link, Thanks Binx. The approach they show may be a little too hard for some us that are mechanically challenged. Any simpler, yet effective approaches that work for stock assemblies?
