Old 08-12-2015, 09:21 PM   #1
Slantwindshield
Default Lowering a Model A
16" tires, how do you lower the rear end of an 29 A?
Slantwindshield is offline   Reply With Quote
Old 08-12-2015, 09:26 PM   #2
Tinbasher
Tinbasher's Avatar
Default Re: Lowering a Model A
Take out a couple of spring leafs. See how much it drops.
John Poole
Tinbasher is offline   Reply With Quote
Old 08-12-2015, 09:28 PM   #3
modelafords
Get a 7 leaf roadster spring with reverse eyes, from "A Springs" in PA.
modelafords is offline   Reply With Quote
Old 08-12-2015, 09:36 PM   #4
colin1928
colin1928's Avatar
T Model spring
colin1928 is offline   Reply With Quote
Old 08-13-2015, 01:03 AM   #5
Manager
Manager's Avatar
Get a pipe bender. Leave the shortest leaf, it is tapered for the crossmember, and the 5 longest ones. rearch with the pipe bender. That is 3", I will give it anothe 1" one day when I can be bothered pulling it out again.
Last picture is with a 4" drop front axle as well.
Manager is offline   Reply With Quote
Old 08-13-2015, 08:38 AM   #6
gz
gz's Avatar
8 Leaf Model T Spring. If you have a lightweight car like a roadster you will be fine (unless you carry people in the rumble seat). If you have a heavier car like a sedan you'll need something to keep it from bottoming out (tube shocks, etc).
gz is offline   Reply With Quote
Old 08-13-2015, 03:38 PM   #7
Jeff in BC
Jeff in BC's Avatar
You could try the stupid way and use a BIG effing torch!
And NO I didn't do this.
Jeff
Jeff in BC is offline   Reply With Quote
Old 08-16-2015, 06:56 AM   #8
insomniacshotrods
insomniacshotrods's Avatar
Model T spring back and 4 inch dropped front, mech brakes and all stock running gear, 40 ford wheels. Someday 35 wire wheels.
Enjoy life , it has an expiration date.
insomniacshotrods is offline   Reply With Quote
Old 08-16-2015, 08:16 AM   #9
Joey Anchors
Joey Anchors's Avatar
That Tudor looks great!
Joey Anchors is offline   Reply With Quote
Old 08-16-2015, 09:01 AM   #10
V4F
V4F's Avatar
I used a reversed eye "A" spring with leaves out . front & rear .
now I use coil overs in the rear . all tires are in the fenders .....
V4f
V4F is offline   Reply With Quote
Old 08-16-2015, 07:39 PM   #11
Slantwindshield
Thanks for all the suggestions. I will try some of them.
Old 08-16-2015, 07:54 PM   #12
Bob C
Like this
Bob
Old 08-16-2015, 10:29 PM   #13
ian Simpson
Sandbags in the rear seat.
ian Simpson is offline   Reply With Quote
Old 08-18-2015, 09:22 PM   #14
Slantwindshield
Stock Model T rear spring? Remove any leafs? Reform? Any weight added? I really like the way it came out. Thanks. Howard
Old 08-18-2015, 09:25 PM   #15
Slantwindshield
Insomniacshotrod...above question is for you. Thanks. Howard
Old 08-19-2015, 09:17 AM   #16
COOTER
How did you create enough clearance for your tie rod?
COOTER is offline   Reply With Quote
Old 08-19-2015, 09:29 AM   #17
GrandpasA
GrandpasA's Avatar
That black Tudor looks killer...!
GrandpasA is offline   Reply With Quote
Old 08-19-2015, 10:47 AM   #18
dalton
COOTER,
You have to cut your balls off, all 3, taper drill the steering arms for "B" balls and install the from the bottom. If you want to run mechanical brakes, build a stand-up to keep the actuating arm perpendicular to the backing plate. You will also have to connect your drag link from the inside, but that will be obvious. I can't remember exactly, but you may have to heat up your arms and bend them accordingly.
Dalton
dalton is offline   Reply With Quote
Old 08-19-2015, 11:19 AM   #19
az58cameo
OUCH, i only have two!!!!!!!!!!! Sorry could not help it Lol.....
Allen
az58cameo is offline   Reply With Quote
Old 08-19-2015, 04:34 PM   #20
Manager
Manager's Avatar
He will probably be back to answer but I think you leave the T spring stock and put the top leaf off the model a spring on as the T spring is narrower and will be loose in the crossmember and use some thick washers to space the shackles. The T spring has a diferent shape which is what I copied when I bent the A spring. If you decide to try a reverse eye spring just remember when reinstall time comes you can't use a spreader so you have to put the main leaf on the rear end first and then assemble the spring.
Cooter for front tie rod clearance you can also use 32-24 stubs .
