11-29-2014, 12:16 PM | #1 |
motor mounts for a 37 pickup
My 37 pickup came with a 1940 flathead installed in it. It had the stock rubber biscuit motor mounts. I see where many older frames need the u shaped after market spacers to install a later motor. What years need the additional spacers for clearance?
11-29-2014, 01:42 PM | #2 |
Re: motor mounts for a 37 pickup
1949-1953 motors using the truck or Mercury Water pumps. Your '40 motor should not need the spacers.
11-30-2014, 12:09 PM | #3 |
The '49-53 8BA/8CM engines need the '49-50 Merc spacers to allow for the shorter ears on the truck/Merc pumps. The U adapter corrects the bolt off-set.. **This viable only applies to the '48 and earlier vehicles. Any '32-48 V8 engine is a direct swap, with some limitations, such as exhaust manifold clearances, oil pans, etc., into any '48 and earlier vehicle.
See attached pix..
Bill.... 36 5 win cpe Last edited by blucar; 12-01-2014 at 11:16 AM. |
11-30-2014, 02:00 PM | #4 |
A 37 with a 40 engine, no issues or spacers needed. Martin. |
