Old 08-30-2011, 02:52 PM   #1
William H. Blalock
Default Transmission Identification
I have access to a Ford overdrive transmission with identifying numbers as follows: 1A-7006-A-3.90 to 1 R-10F-1 WG Div-W2. Obviously it is a Warner Gear Div. overdrive transmission with a ratio of 3.90 to 1. The question is what was it originally installed in and in what year? Thanks.
William H. Blalock is offline   Reply With Quote
Old 08-30-2011, 04:05 PM   #2
Mac VP
Mac VP's Avatar
Default Re: Transmission Identification
The 1A-7006 (gearbox casting number) suggests that this is a 1951 Ford passenger car trans. Those were all R10 overdrive units. Not sure what the 390 represents since they all had the 27 tooth cluster gear (2.78:1 on first gear). There are other physical ID charactoristics that would confirm the 1951 vintage. Its usefulness depends on what you want it for. Is it the correct input shaft spline? Tailhousing mount in the right location? Etc.
VANPELT SALES LLC
Cincinnati, Ohio
Office: 513-724-9486
www.vanpeltsales.com
www.classictransmission.com
Mac VP is offline   Reply With Quote
Old 08-30-2011, 04:07 PM   #3
William H. Blalock
Thanks Mac. That information is very helpful.
Old 08-30-2011, 05:32 PM   #4
rotorwrench
rotorwrench's Avatar
There are only subtle differences between the transmissions from 51 thru 53 Ford and Mercury cars. The all had the 1-inch 10 spline input. The shift housing arragements differed for several different applications. front bolt patterns were all the same. Many of the cars they were used in came with the 3.92:1 rear axle ratio.
rotorwrench is online now   Reply With Quote
Old 07-02-2020, 11:43 AM   #5
Trey-Deuce
Trey-Deuce's Avatar
Mac,
I have two Overdrive transmissions, apparently for F-100s, and would like your input into what group of year models these might pertain to:
Casting number 1A7006-A & R10F-1,
Casting number AF7006-A & R10F-1
Thanks for your help.
Trey-Deuce is offline   Reply With Quote
