Old 10-19-2017, 07:53 PM   #1
john_gto
Default ZENITH 2 sidebowl carb question
Recently acquired a Zenith 2 side bowl carb . Both the choke driver and side bowl filter housing appear to be made of brass. The existing zenith side bowl carb on my 31 SW has a cast iron filter housing and a cadmium coated choke driver. From my research the latter appears to be correct and several previous posts acknowledge the brass choke driver as aftermarket .
Has anyone seen a brass side bowl filter housing ?
John
john_gto is offline   Reply With Quote
Old 10-20-2017, 07:21 PM   #2
john_gto
Default Re: ZENITH 2 sidebowl carb question
added photos -
Old 10-21-2017, 06:40 AM   #3
john_gto
Wondering if the carb rebuilders have any input on this .
Thanks
John
Old 10-21-2017, 11:54 PM   #4
Mike V. Florida
Mike V. Florida's Avatar
John
Originally,
Beginning in May 1931 with the introduction of the
indented firewall, a cast iron filter bowl was mounted on
the side of the carburetor with a cadmium plated bolt and
two tan or reddish brown fiber washers. Cast iron sediment
bulbs were dull black, gasoline resistant Japan enamel.
Old 10-22-2017, 09:21 AM   #5
TinCup
TinCup's Avatar
My father would always remind me that I wasn't the first person to handle the Model A Parts on my car. The brass choke driver is probably a replacement but if the sediment bowl is brass then that is a mystery as I have never seen or heard of such a thing.
TinCup is offline   Reply With Quote
Old 10-22-2017, 05:09 PM   #6
john_gto
Thanks for the reply TinCup - I have rechecked and all indications are that it is brass . Very unusual as far as I can tell .
John
Old 10-23-2017, 05:37 PM   #7
john_gto
There are also markings on the carb castings C52 on the bottom part and G12 on the Top - any idea what their significance is?
Old 10-23-2017, 06:03 PM   #8
RonC
RonC's Avatar
Does a magnet stick to it?
RonC is offline   Reply With Quote
Old 10-23-2017, 06:40 PM   #9
john_gto
No that is the first thing I checked - all the threads and inside of the casting shows it is clearly brass.
Old 10-23-2017, 09:11 PM   #10
RonC
RonC's Avatar
Are the markings indented? Can you post pics of markings?
Old 10-24-2017, 04:45 AM   #11
john_gto
Thanks for the reply RonC - the markings on the upper part are indented and the lower ones are raised - see third picture . The Zenith 2 marking is indented with a - between the Zenith and 2
Old 10-26-2017, 11:32 AM   #12
Carb Guy
Carb Guy's Avatar
I just rebuilt a carb that had a brass or bronze filter on it, it was no good at all as someone drilled out the gas inlet and no way to hook up the gas line. Also the drain valve was not the right thread size and no drain hole in it. The bolt that holds the sidebowl to the carb was made wrong the hex head was way bigger than the standard size. Had to replace it wth the right sidebowl. First and only I ever saw like that in all the years I have rebuilding carbs
Carb Guy is offline   Reply With Quote
Old 10-27-2017, 06:23 PM   #13
john_gto
Thanks for the reply Carb Guy - on mine everything is correct . Will try to get more detailed pictures showing just the sidebowl filter housing.
Old 10-29-2017, 01:55 PM   #14
john_gto
Here are some more pictures of the brass sidebowl filter housing.
