04-10-2024, 05:05 PM | #1 |
Oil capacity clarification
As I continue on my 10 year refurb of my pickup, I'm finally ready to try to start the engine, an 8BA that I had Gary Sharkey (GosFast) build for me a few years ago. Of course I want to be sure I have good oil pressure before actually starting the engine.
I have read a number of threads regarding oil capacity. The only thing that seems certain from my limited research is that it seems there is not a very definitive answer. As I started to fill the crankcase with oil, I carefully measured the amount going in. I filled the oil filter as best I could which is a remote spin on type, dumped some down towards the oil pump and then started filling normally. When I got to 3 quarts, it registered full on the dipstick. I don't believe for a second that 3 qts. is enough oil, but what is going on? The dipstick I have is a reproduction I believe but I'm not sure. It is marked on the dipstick as being 8BA. I believe the pan is for an 8BA but again, I'm not certain. My coupe has a dipstick marked as 8RT which, if I used this dipstick, would allow me to add another quart before registering full. BUT...the coupe also has a different pan on it. Can someone please point me in the right direction on this? I don't want to screw this up. Thanks, Heard
Do I look like I have a plan B? |
04-10-2024, 06:09 PM | #2 |
Re: Oil capacity clarification
I have two 8BA's. Tube should measure 7 3/4" extended from the fitting on the oil pan.
The FULL mark should be 12 1/2" below that. |
04-10-2024, 06:47 PM | #3 |
I’d put five quarts in there then scribe a new line on the dipstick.
04-10-2024, 07:41 PM | #4 |
04-10-2024, 08:30 PM | #5 |
Last week I took a 1949-53 8RT oil pan with the correct length tube and matching 8RT dip stick and placed it on the ground and added 1 qt of water to see what levels it reached on the dipstick. It took 6 quarts of water to reach the FULL mark on the dip stick.
04-10-2024, 08:51 PM | #6 |
1 qt. water level was 1 1/2 in. below tip of dip stick. 2 qt. water level 3/4 in. below dipstick. 3 qt. water just touched tip of dipstick 4 qt. water level at the top of the LOW mark and bottom of the SAFE mark 5 qt. water level in the middle of the SAFE range on dip stick 6 qt. water level at the FULL line on dip stick If you run a filter maybe a 1/2 qt. more of oil should be added. Measurement info. is shown below. Notice DIPSTICK is STAMPED 8BA from factory. There is no baffle in the 8RT pan. FINAL NOTE: The last photo shows another dipstick and tube I have available if you need it. Last edited by 19Fordy; 04-10-2024 at 09:22 PM. |
04-10-2024, 09:21 PM | #7 |
Totally agree with Ken, put 5 quarts in and then punch mark, chisel mark, hacksaw mark, drill tiny hole like the newfangled cars have, take your pick
04-10-2024, 09:25 PM | #8 |
Avoid the hacksaw as the kerf presents a perfect place for a crack to develop and eventually break the dip stick as it bends upon insertion and removal. Dimple is best.
04-11-2024, 04:41 AM | #9 |
Next is my turn: Since day one 5 quarts (no filter) it showed full on the stick; At 2000 miles change the oil now shows 4 quarts at the full Mark? One would think there would be 10 pounds of sludge in the pan, not so this block was thermo cleaned & bead blasted that came back as pure cast iron. Note this local shop that did that-flatheads are no stranger to them they built 100s . also the engine is original 59A NO truck pan. Midnight gremlins at work again
04-11-2024, 07:50 AM | #10 |
Heard, a picture of your pan will help with capacity, but '49-'53 Ford center sump car pans hold 4 quarts, while the rear sump '49-'51 Merc and truck pans hold 5, so add one quart with the filter for both styles.
04-11-2024, 11:41 AM | #11 | |
I think you have identified the issue. I do indeed have a tube that is 7 3/4", BUT my FULL mark on the dipstick is actually at 13 5/8". This is on a dipstick stamped as 8BA. This also seems to validate what Ken and others have said. I think if I dumped another 2 qts in there, it may very well raise that level to 12 1/2". I'm going to try this and take a measurement at 4 qts and 5 and then just mark the dipstick. And to clarify...I do not have the 8RT pan with the large clean out.
04-11-2024, 11:44 AM | #12 | |
Thanks for this info but I'm curious as to why you would use an 8BA dipstick if you are checking an 8RT pan. The dipsticks are definitely different lengths. I must be missing something.
04-11-2024, 12:54 PM | #13 |
Heard , pm sent
04-11-2024, 01:29 PM | #14 | |
Hope someone else with an 8RT pan and dipstick can chime in. I wonder what the measurements are for the 8BA dipstick with the sump in the middle of the stock pan. |
04-11-2024, 01:55 PM | #15 | |
04-11-2024, 02:06 PM | #16 |
I have an 8RT dipstick which is considerably different than the 8BA which is why I asked the question. Here is the overall difference and a close up.
I ended up putting a total of 5 qts in there. This brought the level to exactly the 12 1/2" measurement that 69A posted. I don't know why the dipstick is wrong but from other threads I've read, it seems like that is not so uncommon. BTW, the 12 1/2" mark is almost exactly aligned with the last 'L' in FULL on the dipstick (8BA) on the left. At least for THIS dipstick. Anyway, I followed what I think is great advice here as usual. Decided to turn it over to check oil pressure. I was able to get 25 psi which I think is good. If not, please yell at me! Thanks guys! Heard
04-11-2024, 02:10 PM | #17 |
Tim, I heard of you being called a "Dipstick" - now I know why!
Just kidding yah! B&S |
04-11-2024, 03:07 PM | #18 |
The most important thing we need to know is the actual level of the oil when "FULL". Too many tube and stick variations.
I got an 8RT pan and put 5 quarts of oil in it. This measured 5" from the top. And 4 7/8" from the top of the dipstick casting on the pan. (45 degree angle and tube removed). The only other possible variation can be the height of the fitting on the pan. Mine measure roughly 2 1/8" from the underside of the pan rail to the top rivet. If the top rivet on your dipstick casting is approx. 2 1/8" from the pan rail. Measure the the length of the tube extended from the casting (screwed in) add 4 7/8" to that. This will be your "FULL " mark. A good idea is to put a smaller mark 5/8" below the FULL level, this equates to one quart low. Last edited by 69a; 04-11-2024 at 11:57 PM. |
04-12-2024, 05:20 PM | #19 |
As an aside, not all sticks were marked as 8RT. I have two identical, one is marked 8RT, one is not.
I dig coal, which provides motivation for EVs. |
04-12-2024, 06:41 PM | #20 |
