Hi Guys: As you can see I've moved to the Rumble seat area of my Sport Coupe. So now I'm trying to sort out the hardware to mount everything. So far I've got the rain gutter hardware sorted out but I'm not sure of what was used to hold in the "Curved panel" that extends the floor. Across the rear at the lower deck lid panel, seems to be 8-32 oval head screws but What holds the front edge to the seat riser. Looks like 1/4 holes? But what head style and what type of nut. Square or Hex. Also the three bolts that go along each side are 1/4" but are they oval head, round head or? And the final question the bolt in the gutter at the bottom that goes into the hinge bracket. What style is it? Round head Hex or?
Thanks for your help.
John Poole Tom W. can you be of help here!!!
