03-22-2021, 05:22 PM | #1 |
Difficulty moving shift lever
My 31 Roadster seems to be getting harder to shift. The gears mesh just fine - it seems like it take more effort to physically move the gear shift lever between gears, no matter which gears. There don't seem to be any other issues with it. Has anyone else had this occur? TIA
03-22-2021, 08:45 PM | #2 |
Re: Difficulty moving shift lever
Here is a series on rebuilding the shift tower I recently completed. You might have some wear in the tower. Do not run the engine with the shift tower off the transmission.
https://m.youtube.com/watch?v=BCIpZuxoLpQ |
03-22-2021, 08:57 PM | #3 |
Thanks Bob!
03-24-2021, 09:21 AM | #4 |
How's the oil level in the tranny, and what condition is it in?
03-24-2021, 09:23 AM | #5 |
Practically new - and full.
03-24-2021, 10:41 AM | #6 |
03-24-2021, 11:01 AM | #7 |
Ahhh. That could be it. I've only taken it out recently on cold (for Southern California) mornings. But yes, it's the 600w oil. I'll leave it for a bit and see if the issue gets better now that we're going to be warming up. Thanks!
03-24-2021, 11:12 AM | #8 |
If it’s a thick oil issue, it should get better as you drive further. Take it out for a 20 mile drive and see if it shifts easier after it gets warmed up.
03-24-2021, 12:25 PM | #9 |
Yeah, define cold!! Cold that hampers shifting is generally thought of (in my mind) when the lube is in the 30° range and under. Surely SoCal has not been that cold, has it??
03-26-2021, 02:13 PM | #10 |
**UPDATE** - Well, the fordbarn comes through again. Took the roadster out today when it is 65 - 70 degrees and it shifts just fine. Before when I noticed the issue, it was 45 - 50 degrees in the morning. It has since warmed up a bit.
Thanks much! @Brent in 10-uh-C - Well, no it hasn't been THAT cold but we don't "winterize" cars here, so it may be a function of that. Thanks! |
03-26-2021, 02:21 PM | #11 |
Simple fix, this time.
03-26-2021, 03:28 PM | #12 | ||
I have experienced stiff shifting in both the trans and Mitchell early in the morning until things get warmed up. One of the reasons I run 10W-40 oil in the engine also. |
11-15-2021, 07:22 PM | #13 | |
What do you do if the ball at the bottom of the shift lever is worn badly - can it be repaired, or does it have to be replaced ? Many thanks - Jim |
11-15-2021, 09:48 PM | #14 |
The ball can be built up with weld and then shaped with a file. The shift lever would need to be pulled to do this.
11-16-2021, 07:27 AM | #15 |
Mitchell, who modify Model A transmissions for synchro for 2nd and 3rd and make an overdrive, recommend the multi-grade oil 85W-140 in their equipment. This modern oil will extend the life of your transmission and make shifting in cold temperatures easier. It acts like thinner oil in colder temperatures and thicker oil in warmer temperatures. The viscosity is like the old 600W in warmer temperatures.
Ford recommended adding some kerosene in the transmission in cold weather. Exact words from Ford on page 375 of the Service Bulletins is "M-533 lubricant used in the transmission, differential and dual high should be thinned with 10% kerosene for cold weather operation." Cold weather operation is not defined but they probably meant freezing weather. The multi-grade oil will do the same thing.
A is for apple, green as the sky. Step on the gas, for tomorrow I die. Forget the brakes, they really don't work. The clutch always sticks, and starts with a jerk. My car grows red hair, and flies through the air. Driving's a blast, a blast from the past. Last edited by nkaminar; 11-16-2021 at 08:47 AM. |
