Old 10-30-2017, 09:48 AM   #1
sidevalve8ba
sidevalve8ba's Avatar
Default Side-shift, open-driveshaft transmission question...
I have a transmission that I acquired a few years ago in a trade for some other Ford "stuff" and I am wondering what the application may be. It is a side-shift, open-drive shaft trans. that I would guess would have come from a pickup truck. For some reason I thought all of those were top-shift transmissions. Were some of them column-shift?
The transmission is apart but complete. I've added a couple of photos.
Thanks
The more I learn about new automobiles, the more I value my old ones.
sidevalve8ba is offline   Reply With Quote
Old 10-30-2017, 09:50 AM   #2
Ross F-1
Ross F-1's Avatar
Default Re: Side-shift, open-driveshaft transmission question...
F-1's came with column shift from '51 on.
'52 F-1, EAB flathead
Ross F-1 is offline   Reply With Quote
Old 10-30-2017, 09:54 AM   #3
40cpe
40cpe's Avatar
I can't tell you about commercial column shifts, but many have been modified over the years. The serial number on the case might give you some hint of the year or application of the case.
40cpe is offline   Reply With Quote
Old 10-31-2017, 10:54 AM   #4
'36 5W
'36 5W's Avatar
As I recall, the 3 speed 1/2 tons were column shift, and 4 speeds in both 1/2 & 3/4 tons
were all topshift versions.
'36 5W is offline   Reply With Quote
Old 10-31-2017, 12:58 PM   #5
rotorwrench
rotorwrench's Avatar
The commercial (F1) ones for 1951 may have had the late type gears. It is easy to convert the old side shift types to open drive if a person has the parts to do it out of the commercials from 1942 thru 1950. All a person needs is the rear support housing and the mainshaft.
