03-09-2016, 08:48 AM | #21 |
Re: Sacrificial anode attachment.......
Can't make that call. The installation in the upper hose is as I recall from the instructions on a similar anode years ago.
03-09-2016, 09:20 AM | #22 |
West marine sells the one with brass nut,put in the bottom tank
03-09-2016, 10:03 AM | #23 | |
http://www.no-rosion.com/tech_coolant.htm another read http://papers.sae.org/490093/ Scroll down here about 1/2 way and read about galvanic properties http://www.tc-11.com/understanding_corrosion.htm R Last edited by Ronnie; 03-09-2016 at 10:14 AM. |
03-09-2016, 10:19 AM | #24 |
Been using no-rosion in my '48 F-1 for a few years with good results. Some time in the past somebody put the wrong head gaskets on and caused a water leak. Was using no-rosion then and was impressed with how clean the cooling system was. It has been three years since I did this and no cooling issues. The engine is a 276ci. with aluminum heads and using straight water with the proper amount of no-rosion.
03-09-2016, 11:03 AM | #25 |
Thanks for all the input. As usual lots of good information and opinions.
The more I learn about new automobiles, the more I value my old ones. |
03-09-2016, 11:07 AM | #26 | |
Adding an anode? For what?
03-09-2016, 11:32 AM | #27 |
To be like the Irishman wearing two condoms; to be sure, to be sure!
03-09-2016, 12:20 PM | #28 |
Once a Clinton / Trump supporter always a supporter you won't change their mind.
Same here. But did you know all hot water heaters have a zinc anoide? No fancy Chemicals in there? Wonder why...
Thanks - 30-9 1939, 1940 |
03-09-2016, 12:33 PM | #29 | |
Not an easy job to get out the first time. R |
03-09-2016, 12:46 PM | #30 |
Fifteen years ago, I put together a 32 with an aluminum headed merc flatty. I ran straight water till I was sure there were no cooling system problems. I figured that I would change over to anti freese as soon as I got the chance. One day I went to start my car and the motor was locked up. I pulled the plugs and one cylinder was full of water. The aluminum head had a big spot eaten away around one of the copper crush rings in the head gasket. I welded up the bad spot, filled my motor with anti freeze and most importantly, put a Pencil zinc in one of the tapped spots in the head. 15 years later, no problems! If you go online and look up "Galvanic series" you will see a list of metals, from the most noble to the least noble. The farther apart on the series the less happy metals are in the presence of an electrolite {water} Copper or brass and aluminum are pretty far apart, and should be protected. The pencil zinc is cheap insurance. By the way I never used head gaskets with copper on aluminum heads again. Rich
03-09-2016, 12:53 PM | #31 |
I think some of you guys have too much time on your hands.......
03-09-2016, 01:28 PM | #32 |
Here's another good link > http://www.ve-labs.net/electrolysis-101
03-09-2016, 01:49 PM | #33 |
Simply because there are NO "fancy" chemicals in there... just water and all of the associated minerals.
03-09-2016, 01:56 PM | #34 | |
