12-21-2014, 08:08 AM | #1 |
30 CCPU Heater Hole
12-21-2014, 08:28 AM | #2 |
Re: 30 CCPU Heater Hole
Manifold heater
12-21-2014, 08:33 AM | #3 |
Right, but are there different styles and manufacturers of the manifold heaters?
12-21-2014, 08:34 AM | #4 |
CWilson, the hole is for a aftermarket manifold heater. The one used in my picture is the Autolite. The exhaust manifold that it is setting on has a waffle type configuration which in your picture isn't the same. There is a type of autolite cover that is made for the standard exhaust manifold but I am not sure how much heat is captured compared to the waffle type. Afordman31
12-21-2014, 08:40 AM | #5 |
There were many different aftermarket manifold heaters for the Model A. I don't know of any lists of them. What you might do is borrow as many heaters as you can find to set on your engine to see if any line up with your hole. Good luck.
12-21-2014, 08:46 AM | #6 |
12-21-2014, 08:48 AM | #7 |
I had been told that although there were many heaters made, they all had the heat exit at the same spot on the firewall. I have three and they are all the same.
Wayne |
12-21-2014, 08:50 AM | #8 | |
Is this the kind of manifold you have? |
12-21-2014, 08:56 AM | #9 |
12-21-2014, 09:14 AM | #10 |
CWilson
I just looked up a post that I put on here 11-25-12 asking about the non waffle type of heater cover. Go to search, type in Autolite heater identification. You will see the difference in the heater covers. Afordman31 |
12-21-2014, 09:22 AM | #11 |
