12-20-2014, 03:59 PM | #1 |
E28 Carb Jets
In the process of chasing an exasperating slow leak via my carburetor, went through the basic steps (level the float, gaskets, etc.). Satisfied all was okay, moved on to the jets. Doing so, uncovered a dilemma (at least to me)
* Left: Holley (double venturi) lower bowl. Note large end with no solder in the cap jet. Assumed someone had cut off the top, making it shorter and likely the source of my overflow leak. Disassembled, found #19 stamped on the hex, found to be same height at Zenith (sorry, photo is a little misleading due to angle of pix). * Right: Zenith (single venturi - no number on bowl). Note stepped end and small opening in soldered tip (with slight depression). #20 stamped on hex. ?? Is/should there be a difference in the style (#) of the cap jets (i.e. double vs single venturi)? Don’t have a wire gauge but the Holley jet (left) seems to be a slightly larger orifice than my Zenith (right). PS: If my Holley cap jet does, in fact, need to be resoldered and sized, can someone suggest such a kindred soul? Last edited by Charles Reese; 12-20-2014 at 10:07 PM. Reason: thanks to a friend's sharp eye i have corrected spelling :-) |
12-21-2014, 01:39 AM | #2 |
Registered User
Re: E28 Carb Jets
Charlie
the last photo showing the large opening sure looks wrong to me ill have to look further to see what the problem is unless someone else pipes in tom |
12-21-2014, 06:04 AM | #3 |
Re: E28 Carb Jets
Charles, Like Mot I agree the orifice on the left looks way too large ... BUT...I have come across cap jets from very early carbs with the sized orifice at the base of the jet.- it may be one of those.
The only way of checking jets are OK is to flow test them - over the years people have enlarged the hole with welding wire so the numbers are often way out. Even the new ones can be incorrect. A search on this forum will bring up all the causes of a leaking carb.- when trying to locate the site of the leak I find the only way is to use an airline to dry the carb followed by very close observation. |
12-21-2014, 10:58 AM | #4 |
Re: E28 Carb Jets
Hi Charles,
Both Mr. Steve Parteger & Mr. Rex Reheis in their carburetor manuals, (sold by Model a vendors), address the required concave tips of main & cap jets to prevent carburetor leaks. In your lower left photo, one jet tip is properly provided with a concave tip ..... the other cut off tip is incorrect. The concave tip is provided to counteract fuel capillary action that lessens carburetor fuel seepage & carburetor fuel overflow. When re-sizing main & cap jets, the concave tip is provided after: A. Soldering the opening orifice; &, B. After drilling a new opening in both the main & cap jets with a #61 drill bit; .039" diameter; &, C. Then a proper concave tip is provided with a #189 Dremel Tool. Also, the top of the main jet should be 3/64" to 1/8" higher than the top of the cap jet to compensate for the angle or slope of the engine, or actually the slope of the entire drivetrain. Just hope this helps. Last edited by H. L. Chauvin; 12-21-2014 at 11:02 AM. Reason: typo |
12-21-2014, 11:12 AM | #5 | |
Re: E28 Carb Jets
so now, the chase continues thanks everyone for your patience with my inane questions ... much appreciated |
12-21-2014, 12:21 PM | #6 |
Re: E28 Carb Jets
12-21-2014, 04:15 PM | #7 |
Re: E28 Carb Jets
is the paper gasket between the carb body halves sufficient, or add sealer?
12-21-2014, 04:56 PM | #8 | |
Re: E28 Carb Jets
Useful thread here for leaking carb..http://www.fordbarn.com/forum/showthread.php?t=153107 Last edited by johnbuckley; 12-21-2014 at 05:06 PM. |
12-21-2014, 05:37 PM | #9 |
Re: E28 Carb Jets
Could be a leaking float valve, hole in your float; however, on the other hand, maybe think of it like this:
1. Get a 50' water hose. 2. Hold both ends of the hose perfectly level. 3. Fill the water hose up to both hose end tops to where you can see water just about to overflow from "both" ends of the hose. 4. Imagine the end of the hose in your left hand is your carburetor jet ...... & the end of your hose in your right hand is connected to the fuel in your carburetor bowl. 5. Now, lower the end of the hose in your left hand, (to replicate a jet that is too short), & see water flowing from the top of the lowered hose. 6. Have another person continue to fill the end of the hose in your right hand which is similar to your "full" carburetor bowl with fuel at a higher level. 7. The hose end in your left hand, (just like the jet), will continue to leak & over flow as long as water is supplied to the end of your hose in your right hand mainly because liquids seek their own level when contained as such. A. "If" your shut off valve is leaking; and/or, B. "If" your float valve is leaking, even when parked overnight, your carburetor will continue to siphon & leak fuel all night "if" your jet "is" too short. C. No carburetor gasket at carburetor halves will stop this leak under these particular circumstances. |
12-21-2014, 06:20 PM | #10 |
Re: E28 Carb Jets
The Cap Jets in the early Holley and Zenith Double Venturi Carburetors had the orfice at the bottom of the Jet.
Ron |
