Old 02-16-2013, 10:16 AM   #1
35 coupe
35 coupe's Avatar
Default T5 into a 1950 f1
I am in the process of putting a t5 in my truck, and wondering what the angle of the drive shaft should be. I took measurements of it when the 3 speed was in it. but the t5 is about about a foot longer. THANKS
35 coupe is offline   Reply With Quote
Old 02-16-2013, 10:29 AM   #2
gearhead1952
gearhead1952's Avatar
Default Re: T5 into a 1950 f1
Match the angle of the pinion on the rear axle. Should be somewhere between 0 and 3 degrees if you have the stock axle and original engine.
gearhead1952 is offline   Reply With Quote
Old 02-16-2013, 05:26 PM   #3
Butch11443
Butch11443's Avatar
The engine should be 3* down in the back to keep the carburetor level. This will probably match the pinion being 3* up which it should be.
Butch
Butch11443 is offline   Reply With Quote
Old 02-16-2013, 08:25 PM   #4
35 coupe
35 coupe's Avatar
Thanks
Old 02-16-2013, 08:33 PM   #5
Shadetree
Shadetree's Avatar
How about some pictures of this project? Lots of F1 owners on this site.
Thanks
Son, you will never blow an engine up in high gear.
Shadetree is offline   Reply With Quote
Old 02-16-2013, 08:51 PM   #6
PeteVS
PeteVS's Avatar
There was a long thread a few months ago on what seems to be the same topic- T5 into an F1. Here's the link:
http://www.fordbarn.com/forum/showth...r+f1&showall=1
Don't never get rid of nuthin!
PeteVS is offline   Reply With Quote
Old 02-16-2013, 09:18 PM   #7
Shadetree
Shadetree's Avatar
PeteVS,
Thanks! Bugsiegel did a super job of documenting this procedure.
Old 02-16-2013, 10:07 PM   #8
havi
havi's Avatar
Subscribed. I started doing the same thing. I'll say you need to figure out how to keep the original crossmember secured, as it's a key component of the F1's frame, brake system, pedals, etc. I plan on modifying an F2 crossmember for mine. I'll also have a second crossmember to hold the trans, and a bolt-on "skidplate" to join the two together.
I'm just an old truck guy trapped in a hotrodder's world.
havi is offline   Reply With Quote
Thread Tools
Display Modes
