05-14-2011, 12:14 AM | #1 |
4 Speed AA transmission in A Pickup
I have seen when looking thru but now cant find an article in the Restorer Magazines on a four speed AA transmission as fitted to some Model A Pickups 1930 models?
anyone know which volume issue? or year issue? |
05-14-2011, 12:18 AM | #2 | |
Re: 4 Speed AA transmission in A Pickup
i dont know the issue, but i have AA complete trany that came out of a stock '29 pickup if anyone needs such. |
05-14-2011, 07:53 AM | #3 |
05-14-2011, 11:19 AM | #4 |
A pal of mine in the 50's had a 4 speed trans in his '30 coupe so it was not original. He bought a 31 CCPU and we swapped transmissions no problem.
05-14-2011, 12:08 PM | #5 |
Why would you wanna do that? Got some stumps to pull? The granny gear is really low. As I understand it, you need to change the uni and clam shells.
clem |
05-14-2011, 12:18 PM | #6 |
05-14-2011, 01:59 PM | #7 | |
I have a pick-up chassis that came out of the panhandle of Texas (flat country) that was under an 82B pick-up that had a factory-installed AA four-speed transmission. My point is that many may not have been for pulling hills (--or parades ) as much as the ability to "chore" with it (idling along in 1st), and the ability to run a PTO off the side of the transmission to power belted equipment. . |
05-14-2011, 08:53 PM | #8 |
I have one in my pickup and know that Ford did put some 4 speeds in pickups at the factory, and am after info. thanks so far.
