08-29-2020, 03:47 PM | #1 |
Ford rims ?? Wide
Was wondering if anyone might know what these rims came off of and what year range .thanks
08-29-2020, 04:10 PM | #2 |
Re: Ford rims ?? Wide
'36 thru '39 Ford wheel. Welcome to FordBarn! DD |
08-29-2020, 04:26 PM | #3 |
Hey thank you I appreciate it !
08-29-2020, 04:27 PM | #4 |
Do you know which size radials will fit it ? Currently has 6.50x16
08-29-2020, 04:28 PM | #5 |
could be the wheels off a 3/4 and 1 ton truck from 1937 to 47
08-29-2020, 04:49 PM | #6 |
Making the simple complicated for over 30 years. Last edited by 51504bat; 08-29-2020 at 04:53 PM. Reason: additional info |
08-29-2020, 06:25 PM | #7 |
Far as I know, 60hp car 3.5 width, most cars 4”, pickup and Mercury 4.5”
I had some widened 2”, to fit 750 tires |
08-29-2020, 07:28 PM | #8 |
08-29-2020, 08:28 PM | #9 |
My 1 ton as I remember has a 7.5” 6 lug Split rim,
The picture with 650 tire probably the rim is the max for wide 5 Stock, 4.5”width Research I had done, I believe the 3/4 ton pickup has extra leaves, still wide 5 pattern 4.5” 4” wheel used 600 tire 3.5” used 550 tire |
08-29-2020, 09:13 PM | #10 |
Guys....It's obvious that this is NOT an original tire on this wheel. People 'up-sized' tires all the time. A 6.50 tire on a 4" wheel was a normal occurrence. '36 thru '39 'wide-five' wheels were all 4"-wide except for the very few 3-1/2" V8-60 wheels that were produced. Even with no pressure in this tire, if you'll pay attention to the tire/rim between 8 o'clock and 4 o'clock, it's easy to see that this is the regular ol' narrow, 4" wheel. Heck, the second picture shows a big ol' 7.50-R16 that we put on a 16 X 4-1/2" Ford wheel. It's been done to death! DD ....... |
08-30-2020, 11:04 AM | #11 |
The majority of the wide five wheels will have the date/manufacture, Ford or KH with month/year stamped into the back side of the bead area, generally at 6 o-clock from the valve stem.
I would doubt very much that there are very many Standard Series 16 x 3.5 wheels exist now. The 550 x 16 tire would have been an odd tire size in '36, most people would have opted for the 600 x 16 tire
Bill.... 36 5 win cpe |
08-30-2020, 03:40 PM | #12 | |
08-31-2020, 10:41 AM | #13 |
According to the EFV8 Club, 35-36 book, Wheels And Tires: "In July of 1936, standard model cars were equipped with 5.50 x 16 four ply non-script tires and the rim was reduced from 4 inches wide to 3 1/2 inches wide".
08-31-2020, 12:13 PM | #14 |
I had a 36 std 5W a few years back and all the 5 wheels which were original to the car were 3.5" wide.
08-31-2020, 06:01 PM | #15 | |
Here is a 16 x 5" Kelsey wide five wheel that I have. I believe it's from a '41 pickup, 3/4 or 1 ton... Click on pix to Enlarge
My Wife Says That I Never Listen to Her, I Think That's What She Said If mama ain't happy, ain't nobody happy. But if daddy ain't happy...RUN |
08-31-2020, 07:16 PM | #16 |
Like a skunk in the wind, it's coming back to me now. You ARE correct in that those last few production '36 Standards had the skinny wheels. DD
08-31-2020, 08:46 PM | #17 | |
Not 1 ton. Photo shows a '38 1 ton. The wheels are 5 lug and not wide 5.
Making the simple complicated for over 30 years. Last edited by 51504bat; 08-31-2020 at 08:56 PM. |
08-31-2020, 10:47 PM | #18 |
favorite stock car racer wheels, what Lanny shows
09-01-2020, 09:42 AM | #19 | ||
The really difficult versions to find are the 1940 3-1/2" wide with 5 on 5-1/2 bolt pattern. I had two of these and sold them at relatively high dollars.
John "Never give up on what you really want to do. The person with big dreams is more powerful than one with all the facts". Albert Einstein Last edited by JM 35 Sedan; 09-01-2020 at 09:47 AM. |
09-01-2020, 10:35 AM | #20 |
I wonder? Were the '37-39 Lincoln wheels wide 5 on 10".. If they are I would make book that the Lincoln wheels are wider than the Ford. A comment was made earlier in this thread that the Merc wheels in 39 were 4.5".
Thread Tools | |
Display Modes | |
