08-25-2020, 04:18 PM | #1 |
unimportant question for '41-'48 owners
yesterday, while installing the right front inner fender panel on my '46,i noticed what appears to be 4 factory made holes in the area next to the battery tray. 2 about 1/4" & 2 about 3/8". any one else have these? what might they be for? thanks!
08-25-2020, 04:44 PM | #2 |
Re: unimportant question for '41-'48 owners
Yes, I have them too, on my '47. Thought maybe they for attaching some type of accessory but couldn't find any suggestions in that section of the 1941 - 1948 Ford Book.
If they are for mounting something inside the engine compartment, it would have to be fairly narrow in order to fit between the panel and the battery. |
08-26-2020, 11:14 AM | #3 |
I looked at my '46 Super Deluxe Coupe, and only found three. One 1/4" and one 3/8" holes towards the front of the battery, and one 1/4" just behind the stamped crease about 6" ahead of the battery. In any event, they can't be too important, because no one knows what they are for. 😊 When you look under the hood of newer cars, you will find all sorts and types of unused holes, as well as a number of unused electrical connections, depending on what options are installed. Fewer options, more unused holes and connectors.
08-26-2020, 02:31 PM | #4 |
They may be tooling holes, possibly used for holding metal sheet in place when it was being stamped.
08-26-2020, 03:36 PM | #5 | |
That would mean there was a stamping die built to put the holes in and another to stamp something later. That makes zero sense. I'd built more stamping dies than I care to recall - that's not how "it" works.
08-26-2020, 03:37 PM | #6 |
Or... If on a 41-46 MAybe some sort of barckets for a hot air heater?? |
08-26-2020, 03:49 PM | #7 |
Could it be the holes for steering box mount on a Right Hand drive car.
08-26-2020, 03:50 PM | #8 |
Michael, I was wondering the same thing. As noted, only 1.5 inch clearance between one of the holes and corner of the battery. That's the most narrow space on mine.
08-26-2020, 04:14 PM | #9 |
How about for that windshield wiper vacuum tank? Are these holes in the firewall or inner fender?
08-26-2020, 04:39 PM | #10 |
The windshield wiper vacuum tank was located on the drivers side lower fender area on the '46-'48. Rusty, are there any holes on the drivers side inner fender panel on your car? I'm off to my garage to check out my car.
08-26-2020, 04:50 PM | #11 |
Yes, I just checked and I also have them on my '46 Station Wagon. The mystery continues!
08-26-2020, 05:31 PM | #12 |
What about the funky heater that had duct work in the hood or a hotair heater off the exhaust
I remember the 6 cyl cars had the battery on the opposite side of a V8 |
08-26-2020, 05:32 PM | #13 |
Where was the accessory windshield washer jar mounted on these years?? Surely not that close to the battery I would think.
08-26-2020, 07:54 PM | #14 |
the only holes on the left side were for the horn brackets & they are in a different place.
08-27-2020, 08:41 AM | #15 |
