Old 08-18-2020, 04:16 AM   #1
russcc
Default 59 AB Plug wire set
There is a set of plug wires from, I believe, one of the smaller 60-80"s Dodge V8 engines that fit the Ford Flathead with the 21A distributor. Anyone recall what Cubic Inch engine size those are ? Thank you Fordbarners.
russcc is offline   Reply With Quote
Old 08-19-2020, 08:21 AM   #2
russcc
Default Re: 59 AB Plug wire set
An ideaI got from a long time Ford flathead guy on the plug wires was to use a set from a '70's-80's small block Chrysler product like a 318 to 360 as they have the distributor in the front like the flat motor. Anyone have experience with that setup or have a NAPA # for the wire set ?
Old 08-19-2020, 09:18 AM   #3
GB SISSON
GB SISSON's Avatar
Would those be real wire though? I'm all ears because I'd like a set also. Is the 21a a crab?
'47 1/2 ton pickup next project, '47 one ton panel 99% stock nearing completion, '47 2 ton with 8ba and 9' script stakebed, '46 1/2 ton woodie project,'59 F350 9' flareside pickup with cummins 6at. 'Rusty ol' floorboards, hot on their feet' (Alan Jackson)
Old 08-19-2020, 09:35 AM   #4
russcc
Yes this is for a 59L with a 21A distributor. I have the same setup on the 59 in the roadster and used Belden wires from NAPA, but I can't remember what part # I started with. These are Belden Edge Premium 7 MM, metallic SAE 14. I had to trim some to length an install right angle connectors for the 21A end so they both ends were right angle. Photo.
Old 08-19-2020, 09:51 AM   #5
joe 1950
I purchased mine for my 50 cpe from Jegs high performance i wanted red to match my heater hoses only had to cut and install the distributor ends work great and looks great had them on 24 years no problem
joe 1950 is offline   Reply With Quote
Old 08-19-2020, 09:55 AM   #6
Automotive Stud
Automotive Stud's Avatar
I know it doesn't answer your question, but I bought a roll of wire and I've been making my own plug wires for years. Always a perfect fit...
Automotive Stud is offline   Reply With Quote
Old 08-19-2020, 11:29 AM   #7
51woodie
51woodie's Avatar
Carpenter sells them. I bought a set for my '46 Coupe, P/N 59A-12259, $70.00. They are brown colored which I understand is the correct color for the year.
51woodie is offline   Reply With Quote
Old 08-19-2020, 07:04 PM   #8
russcc
If you are not interested in the correct appearing wire, and don't want to make them up yourself, Brillman's makes 7MM wires to your specs out of black EPDM cover, copper core, with right angle terminals & boots, so you just have to plug & play, $67. for the set, includes coil wire.
Thread Tools
Display Modes
