12-19-2019, 03:39 PM | #1 |
39 fuel tank fitting
Hi where can I get the compression fitting (nut / ferrel) that attaches steel line to tank?
Tried: Ace, auto zone, napa, and plumbing supply.
Thanks Andy 1952 F1 Last edited by adileo; 12-19-2019 at 03:54 PM. |
12-19-2019, 04:44 PM | #2 |
Re: 39 fuel tank fitting
Try some of the V-8 Parts vendors. C and G, Sacramento Vintage Ford, Joe's Antique Auto, etc.
12-19-2019, 05:50 PM | #3 |
Hey Andy...I find it hard to believe you can't find that stuff at a decent parts house in New Joizy. The little kids behind the cash registers at Auto Zone ain't gonna have a clue about fittings. They only know about speakers and floor mats and mud flaps. I would think that any decent NAPA store with some OLD guy running the joint ought to have an "IMPERIAL Fittings" cabinet with all sorts of brass fittings, compression fittings and ferrules, among others. Click the link below to show the broad array of stuff that Imperial offers. When you get to their site, type-in "ferrule" for instance. My God, you ought to be able to find a ferrule almost anywhere besides McDonalds. Good luck...DD
https://www.imperialsupplies.com/bro...ubing-fittings |
12-19-2019, 06:27 PM | #4 | |
I know, I thought like you. I even brought the old one with me.
Thanks Andy 1952 F1 |
12-19-2019, 06:41 PM | #5 |
I have found that "Ford Nuts" (unique male compression fittings) are not generally available, although regular ferules will work. The last time I changed a fuel pump, I had to use a regular pipe thread to flare fitting that took a female flare nut.
12-19-2019, 07:07 PM | #6 |
12-19-2019, 07:22 PM | #7 |
Not my NAPA. I went and he said nope
12-19-2019, 07:58 PM | #8 |
12-19-2019, 08:55 PM | #9 |
Hey Kube, I went to TLP he had them I should have went there first!
12-19-2019, 09:08 PM | #10 |
TLP? Code talk?
12-19-2019, 09:57 PM | #11 |
Mike,
Napa has them??!!! I just had 2,000 of them made to go with our pre bent fuel line kits... |
12-19-2019, 11:37 PM | #12 |
Rock Auto Edelmann 108400 $2.70
12-20-2019, 11:07 AM | #13 |
Rich,
That appears to be a steel nut....is it? Thanks for sharing the Part# !! The originals were brass. Last edited by 35fordtn; 12-20-2019 at 12:05 PM. |
12-20-2019, 11:37 AM | #14 |
Wow! Never thought to look there. Thanks for the source.
12-20-2019, 12:01 PM | #15 |
If you guys ever need these fitting in brass, as mentioned I just had a large QTY of them made.
12-20-2019, 12:58 PM | #16 | |
Andy...Like the others have asked, what is TLP? Google doesn't even know! DD |
12-20-2019, 02:49 PM | #17 |
Sorry TLP is a company here in NJ. The owner is very good friend and huge early (39, 40 coupes deluxe and standard, 40 convertible, 48 pickup, etc, etc, etc) Ford collector. Mike and him are also friends.
12-20-2019, 03:27 PM | #18 |
Just thought I'd add that O'Reilly has (or can get depending on which store)in BRASS. Part #FLA14B.
I went, I saw, I bought the T shirt 51 Ford Deluxe Tudor 32 Ford roadster 39 Mercury Towncar |
12-21-2019, 05:29 PM | #19 |
12-23-2019, 09:44 AM | #20 |
