Old 05-14-2011, 12:14 AM   #1
model.a.paul
model.a.paul's Avatar
Default 4 Speed AA transmission in A Pickup
I have seen when looking thru but now cant find an article in the Restorer Magazines on a four speed AA transmission as fitted to some Model A Pickups 1930 models?
anyone know which volume issue? or year issue?
model.a.paul is offline   Reply With Quote
Old 05-14-2011, 12:18 AM   #2
hardtimes
hardtimes's Avatar
Default Re: 4 Speed AA transmission in A Pickup
paul,
i dont know the issue, but i have AA complete trany that came out of a stock '29 pickup if anyone needs such.
Old 05-14-2011, 07:53 AM   #3
Benson
Benson's Avatar
Paul,
This index might help:
http://www.mafca.com/downloads/Indexes/RINDEX50.pdf
Old 05-14-2011, 11:19 AM   #4
PC/SR
A pal of mine in the 50's had a 4 speed trans in his '30 coupe so it was not original. He bought a 31 CCPU and we swapped transmissions no problem.
PC/SR is offline   Reply With Quote
Old 05-14-2011, 12:08 PM   #5
Clem Clement
Clem Clement's Avatar
Why would you wanna do that? Got some stumps to pull? The granny gear is really low. As I understand it, you need to change the uni and clam shells.
clem
Old 05-14-2011, 12:18 PM   #6
Rowdy
I have 7 or 8 of the AA truck transmissions, so if you need some gears out of one let me know. Rod
Do the RIGHT thing - Support the H.A.M.B. Alliance!!!!
Rowdy is offline   Reply With Quote
Old 05-14-2011, 01:59 PM   #7
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
clem
I have a pick-up chassis that came out of the panhandle of Texas (flat country) that was under an 82B pick-up that had a factory-installed AA four-speed transmission. My point is that many may not have been for pulling hills (--or parades ) as much as the ability to "chore" with it (idling along in 1st), and the ability to run a PTO off the side of the transmission to power belted equipment.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 05-14-2011, 08:53 PM   #8
model.a.paul
I have one in my pickup and know that Ford did put some 4 speeds in pickups at the factory, and am after info. thanks so far.
