Old 03-05-2021, 04:37 PM   #1
Twrench~70
Default 1938 ford standard 60 hp motor
I would like to know if the petcocks on either side of the motor for coolant drain is a right hand or a left hand thread. Doing a head gasket replacement and I need to drain the motor. Or should I leave well enough alone and pull the lower hoses on the radiator. please advise Thank you
Twrench~70 is offline   Reply With Quote
Old 03-05-2021, 05:20 PM   #2
V8COOPMAN
V8COOPMAN's Avatar
Default Re: 1938 ford standard 60 hp motor
Those should be a normal, right-hand, tapered pipe thread. DD
Click Links Below __
T5 W/TORQUE TUBE
V8COOPMAN is online now   Reply With Quote
Old 03-05-2021, 05:23 PM   #3
flatjack9
flatjack9's Avatar
Right hand.
Old 03-05-2021, 05:49 PM   #4
ford38v8
ford38v8's Avatar
If all you intend doing is new head gaskets, just remove the radiator cap and open the drain cock on the radiator. It won’t stain your driveway if you have your garden hose running while doing so.
Alan
Old 03-05-2021, 06:23 PM   #5
Twrench~70
There is no drain cock on the radiator ford38v8. there is only two petcocks under the heads toward the front of the motor. Thank you for your reply
Old 03-05-2021, 06:47 PM   #6
Lawson Cox
Lawson Cox's Avatar
Twrench-70, the petcocks are under the engine, near the front. Not under the heads. LOL. (Don't you hate a 90-year-old smart ass? LOL)
Old 03-05-2021, 08:32 PM   #7
fordor
Why take the peacocks out? Just open them up and drain the motor. That's all I did when I changed the head gaskets. Never removed the entire pepcock.
fordor is offline   Reply With Quote
Old 03-05-2021, 10:16 PM   #8
Twrench~70
I don't want to take them out I just want to know they rotate???/ Right hand thread or left hand thread to open them up. thank you
Old 03-05-2021, 11:23 PM   #9
V8COOPMAN
V8COOPMAN's Avatar
Most automotive petcocks that I've ever opened turn CCW (counter-clockwise) to OPEN. DD
T5 W/TORQUE TUBE
Old 03-06-2021, 09:49 AM   #10
flatford8
flatford8's Avatar
Yes turn the same way as to remove them. That way when you tighten to close, they tighten in the threaded bung also..... Mark
I'm thinkin' about crankin'
My ragged ol' truck up
and haulin' myself into town.
Billy Joe Shaver
Old 03-06-2021, 11:34 AM   #11
Als48
They are probably left-handed valves. They do open by turning counter-clockwise, but do so by screwing the stem off of the seat inward. I've fooled with lots of them.
Al Hook
Als48 is offline   Reply With Quote
Old 03-06-2021, 12:02 PM   #12
Lawson Cox
Lawson Cox's Avatar
They will turn either way to open to close. This ain't rocket science.
Old 03-06-2021, 01:55 PM   #13
V8COOPMAN
V8COOPMAN's Avatar
That answer sounds like some obfuscatory BS that a wanna-be attorney might throw-out in a case that ain't goin' so good! DD
T5 W/TORQUE TUBE
Old 03-06-2021, 03:55 PM   #14
38bill
38bill's Avatar
That's what I was thinking. I think they have a through hole in the stem so no matter which way they turn they open and close.
38bill is offline   Reply With Quote
Old 03-06-2021, 04:34 PM   #15
V8COOPMAN
V8COOPMAN's Avatar
Guys....Here's one OPEN, and another one CLOSED. On the CLOSED petcock, notice the "left-handed" thread on the TWISTY thing. As you turn it CCW (counter-clockwise), it OPENS! DD
T5 W/TORQUE TUBE
Old 03-06-2021, 04:43 PM   #16
Jack E/NJ
Jack E/NJ's Avatar
The petcocks that turn either way to either open & close are on the bottom of the 38 radiator. The thru hole stem and its bore are tapered like a lab burette Jack E/NJ
Old 03-06-2021, 04:50 PM   #17
V8COOPMAN
V8COOPMAN's Avatar
Originally Posted by Jack E/NJ View Post
The petcocks that turn either way to either open & close are on the bottom of the 38 radiator. Jack E/NJ
He's already said there is NO petcock on the radiator. Only the two toward front of block. DD
T5 W/TORQUE TUBE
Old 03-06-2021, 04:53 PM   #18
Jack E/NJ
Jack E/NJ's Avatar
On my 38 there is. The very bottom underside of the radiator as I think Lawson was trying to point out. Plus 2 pipe plugs on each side of the block. Jack E/NJ
Old 03-06-2021, 04:58 PM   #19
jimTN
Sounds like some spurious parts have been installed. Original Ford petcocks were solid brass and could be turned in either direction to open. If you have modern junk wingnut draincocks then that is the problem.
