Old 06-18-2022, 04:21 PM   #1
Lawson Cox
Lawson Cox's Avatar
Default Starter to oil pan bracket
I have searched several ways and cannot find anything on when Ford first started using said bracket. Neither my 34 nor my 36 had one as I recall. Can anyone enlighten me? Thanks a heap.
Old 06-18-2022, 07:40 PM   #2
alanwoodieman
Default Re: Starter to oil pan bracket
look on the oil pan rail for a cut out area on the pan rail, that is to allow the clip to lay flat, I have installed them on a 36 tudor that I believe was the first one I ever saw
alanwoodieman is offline   Reply With Quote
Old 06-18-2022, 07:49 PM   #3
petehoovie
petehoovie's Avatar
I think Ford added it when the 8BA's were introduced...My '53 was equipped with one...
The only thing nice about being imperfect is the joy it brings to others....
"Silver rings, your butt! Them's washers!"
"We shot our way out of that town for a dollar's worth of steel holes!" - from 'The Wild Bunch' - 1969
https://www.youtube.com/watch?v=7NReUd2_0u0
Old 06-18-2022, 07:54 PM   #4
Kube
Kube's Avatar
I'm not 100% certain but believe these were first installed by the factory on the '38 models.
They were for certain, installed on all '39 models through at least 1948.
Although this bracket could be fitted to earlier engines, I do not believe they were correct.
Mr. Rehor? What say you sir?
Old 06-18-2022, 09:01 PM   #5
DavidG
DavidG's Avatar
Perhaps Alan will enlighten us, but in the meantime, my understanding is the that they were a '38 addition; certainly not before.
Old 06-18-2022, 10:06 PM   #6
petehoovie
petehoovie's Avatar
Yeah, my '37 didn't have one....
Old 06-18-2022, 11:52 PM   #7
ford38v8
ford38v8's Avatar
Limited numbers of 81A-11140 support brackets were available for service as early as April 1938, and had apparently been installed in production piecemeal until October 1938, when 100% of production included the bracket, which then carried the 91A prefix. This implies that there may have been at least some early 1939 assemblies that were not so equipped with the bracket. The first engine assembly at 100% production was #4690144, The revised oil pan went 100% production at # 4692175 on the same date, October 5, 1938.
The above information courtesy of Gary Mallast, in the 1938-39 Ford Book, available from the EFV8CA. Just one more example of the goldmine of information contained in the Club's published books.
Alan
ford38v8 is online now   Reply With Quote
Old 06-19-2022, 02:48 AM   #8
DavidG
DavidG's Avatar
Alan, Thanks!
Old 06-19-2022, 10:41 AM   #9
Lawson Cox
Lawson Cox's Avatar
Thanks Alan. Now to round one up and put it on the display engine. 3rd Gen probably the best bet. Is this site great, or what?
Old 06-19-2022, 11:23 AM   #10
rotorwrench
rotorwrench's Avatar
It's a wonder that those two long bolts actually do as well as they do about holding the starters on. There must have been enough of them come loose in those early V8 years that Ford finally decided to add the support clip just in case.
Old 06-19-2022, 11:47 AM   #11
51504bat
51504bat's Avatar
Joe's Antique Auto lists the bracket.
51A-11140Starter to oil pan attaching
bracket ......................................... 39-486.00 ea
Old 06-19-2022, 12:47 PM   #12
Kube
Kube's Avatar
I'd figured cases were cracking due to no bracket and that's why Ford added it.
I know in the 60's, Chevy added a bracket to their starters. Many guys would not reinstall it (kind of a pain to do so) and would subsequently find themselves with a broken starter body.
Old 06-19-2022, 12:48 PM   #13
Kube
Kube's Avatar
That one will work but is not correct for a 39 - 40 engine.
Old 06-19-2022, 03:02 PM   #14
ravedodger
I think there are at least two versions of this clip but so could be wrong. I bought one online new, but the new version didn’t fit my 8BA. I think I found an old one on eBay and it fit perfectly.
ravedodger is offline   Reply With Quote
Old 06-19-2022, 03:48 PM   #15
Kube
Kube's Avatar
Lawson, keep in mind, the 60HP bracket is not the same as the 85.
Old 06-19-2022, 03:57 PM   #16
Lawson Cox
Lawson Cox's Avatar
Thanks. Got a picture of one for 60HP? Ain't nuttin da same it seems. LOL
Old 06-19-2022, 04:32 PM   #17
Kube
Kube's Avatar
I do not have a photo nor do I have dimensions. Sorry.
Old 06-19-2022, 06:01 PM   #18
ford38v8
ford38v8's Avatar
My apologies, I thought about this earlier but my tummy was growling for lunch. The 60 hp version is 82A-11140A1, no pictures found.
Alan
Old 06-19-2022, 07:06 PM   #19
Lawson Cox
Lawson Cox's Avatar
Thanks for the part number, Alan. I'll bet that'll be a booger to locate. Lawson
Old 06-19-2022, 07:13 PM   #20
VeryTangled
VeryTangled's Avatar
Hi Everyone, I'm not sure it helps the 60 horse discussion, but two threads about this bracket with pictures from September and July 2011...
Starter to Oil Pan Support Bracket 1937 Ford
https://www.fordbarn.com/forum/showthread.php?t=48783
36 Starter to oilpan bracket - Opinions requested
https://www.fordbarn.com/forum/showthread.php?t=43762
-Jeff H
Have you thought about supporting the Early Ford V-8 Foundation Museum?
VeryTangled is offline   Reply With Quote
Thread Tools
Display Modes
