06-13-2022, 04:22 PM | #1 |
A top tip when dealing with fluids. This one sucks!
Hello and welcome to Mart's Garage. I needed to swap drain plugs on the big inch flatty in my 32 Sedan. How to do it without losing coolant? I remember Canadian Youtuber AvE mentioning this trick and I thought I would try it. The results were unbelievable. Really, as in I didn't believe it.
Check it out and see how I got on. Mart. https://youtu.be/c1-m06wuo6c |
06-13-2022, 06:29 PM | #2 |
Re: A top tip when dealing with fluids. This one sucks!
Mart, that was terrific!! Assume this would also work to change the drain on the radiator!!
Thanks for posting!! |
06-13-2022, 06:34 PM | #3 |
https://youtu.be/J-2HV8k-kt4 About 3:20 into the above video Mart shows a very clever way to SEE the actual fluid level in your engine/rad and forms the basis of why he's changing the petcock (see pic 2). He was onto this fluid level diagnostic while eventually finding a FUBAR head gasket. Mart, a thought I had when I saw the finished job... I see a future where there's just lick of threads on the end of that pipe with a tire valve cap or something custom made on it. I'm thinking of sand/road grit/etc. getting up in that bugger. We all know how easy it is to swap thanks to this tech tip.
-Jeff H Have you thought about supporting the Early Ford V-8 Foundation Museum? Last edited by VeryTangled; 06-13-2022 at 06:55 PM. |
