#1 |
I’m greasing the chassis today, and the fitting on the interior side of the front brake backplate (by the king pin) will not take grease. This is a surprise because I grease the chassis every 1000 miles, which turns out to be about 3 times a year, and all of the fittings took grease fine last time.
I used a toothpick to make sure there isn’t any debris in the fitting, and I’ve tried a little bit of torch heat with no luck. I don’t want to get carried away with the torch and mess up the hardening of the metal. Can anyone offer me some ideas for how to proceed? Sent from my iPhone using Tapatalk |
#2 |
I assume you have the front end lifted off the ground. If not, you are fighting the weight of the car to force grease in there. Another possibility is that the bush has turned in the stub axle, causing the holes to no longer line up. Disassembly is the only cure if that is so and that might be good idea anyway to make sure all is well.
As youth departs, we trust wisdom shall suffice. |
#3 | |
![]() Quote:
Yes, the wheels are off the car. Sent from my iPhone using Tapatalk |
#4 |
I’ve never had a king pin out of a car. I didn’t know there was a grease hole in the bushing, but I guess that would make sense. I didn’t know the bushing could twist either.
#5 |
Like most things on these cars, king pins are not difficult to work on. If you have either Les Andrews' or Les Pearson's book, there are simple to follow directions. (I prefer Pearson's book)
#6 |
![]() Sent from my iPhone using Tapatalk Last edited by shew01; 05-16-2022 at 08:46 PM. |
#7 |
I ruptured the grease gun hose trying to get what turned out to be a bad adapter to work, but the grease gun is 30+ years old. So, it’s time for a new hose anyway. I had a new spare.
#8 |
Suggest that you get a longer hose, makes greasing easier.
#9 |
If you remove the fitting will it take grease?? If no, replace the fitting.
Paul in CT |
#10 |
purchase a K-D tool number #416 fill it with oil hit it with a hammer and the fitting will be clear, ready for the grease gun, if old hard grease is the problem...........
#11 |
Currently out of stock
About $18 when you can find them
#12 |
![]() Interesting tool. I never knew about it. Google found this link when I searched for KD tool #416. https://www.autotoolworld.com/Gearwr..._p_253188.html Sent from my iPhone using Tapatalk |
#13 |
#14 |
I had to go out to the shop to measure, 24". Stock item, they come in various lengths
#15 | |
![]() Quote:
Thanks. I think my old hose was 18”, and my new one is 12”. As I was pumping the fittings with the 12” hose, I was thinking this was harder than I remembered. The longer hose will probably fix that. Sent from my iPhone using Tapatalk |
Thread Tools | |
Display Modes | |
