01-06-2022, 08:46 PM | #21 |
Re: Sign
If mama ain't happy, ain't nobody happy. But if daddy ain't happy...RUN |
01-06-2022, 08:55 PM | #22 |
Re: Sign
01-06-2022, 08:59 PM | #23 |
Re: Sign
01-06-2022, 09:05 PM | #24 |
Re: Sign
If mama ain't happy, ain't nobody happy. But if daddy ain't happy...RUN Last edited by Lanny; 01-06-2022 at 11:36 PM. |
01-06-2022, 11:23 PM | #25 |
Re: Sign
01-06-2022, 11:52 PM | #26 |
Re: Sign
01-07-2022, 12:55 AM | #27 |
Re: Sign
"Lanny" wins.
01-07-2022, 10:55 AM | #28 |
Re: Sign
This is one of my old favorites. Actual sign on the old cell phone lot at O'Hare airport in Chicago.
https://www.nirgv8.org |
01-07-2022, 03:18 PM | #29 |
Re: Sign
01-07-2022, 03:24 PM | #30 |
Re: Sign
01-07-2022, 04:19 PM | #31 |
Re: Sign
No discussion of this type should ever go without the Turboencabulator because it directly applies to early Fords.
The Turbo-Encabulator in Industry. For a number of years now, work has been proceeding to bring perfection to the crudely conceived idea of a machine that would not only supply inverse reactive current for use in unilateral phase detractors, but would also be capable of automatically synchronizing cardinal grammeters. Such a machine is the "turbo-encabulator." Basically, the only new principle involved is that instead of power being generated by the relative motion of conductors and fluxes, it is produced by the medial interaction of magneto-reluctance and capacitive directance. The original machine had a base plate of prefabulated amulite, surmounted by a malleable logarithmic casing in such a way that the two spurving bearings were in direct line with the pentametric fan. The latter consisted simply of six hydrocoptic marzelvanes, so fitted to the ambifacient lunar waneshaft that side fumbling was effectively prevented. The main winding was of the normal lotus-0-delta type placed in panendermic semiboiloid slots in the stator, every seventh conductor being connected by a nonreversible tremie pipe to the differential gridlespring on the "up" end of the grammeters. Forty-one manestically spaced grouting brushes were arranged to feed into the rotor slipstream a mixture of high S-value phenylhydrobenzamine and 5% remanative tetryliodohexamine. Both of these liquids have specific pericosities given by P=2.5Cn6.7 where n is the diathetical evolute of retrograde temperature phase disposition and C is Chlomondeley's annular grillage coefficient. Initially, n was measured with the aid of metaploar refractive pilfrometer (for a description of this ingenious instrument, see Reference 1), but up to the present, nothing has been found to equal the transcendental hopper dadoscope (2). Electrical engineers will appreciate the difficulty of nubing together a regurgitative purwell and a supramitive wennelsprock. Indeed, this proved to be a stumbling block to further development until, in 1942, it was found that the use of anhydrous nangling pins enabled a kryptonastic boiling shim to the tankered. The early attempts to construct a sufficiently robust spiral decommutator failed largely because of a lack of appreciation of the large quasi-piestic stresses in the gremlin studs; the latter were specially designed to hold the roffit bars to the spamshaft. When, however, it was discovered that wending could be prevented by a simple addition to the living sockets, almost perfect running was secured. The operating point is maintained as near as possible to the h.f. rem peak by constantly fromaging the bitumogenous spandrels. This is a distinct advance on the standard nivel-sheave in that no dramcock oil is required after the phase detractors have been remissed. Undoubtedly, the turbo-encabulator has now reached a very high level of technical development. It has been successfully used for operating nofer trunnions. In addition, whenever a barescent skor motion is required, it may be employed in conjunction with a drawn reciprocating dingle arm to reduce sinusoidal depleneration. References 1. Rumpelvestein, L.E., Z. Elektro-technistatisch-Donnerblitz vii. 2. Oriceddubg of the Peruvian Academy of Skatological Sciences, June 1914. For more than 50 years the Arthur D. Little Industrial Bulletin has endeavored to interpret scientific information in terms that the lay person could understand. "The Turbo-encabulator in Industry" is the contribution of J.H. Quick, graduate member of the Institution of Electrical Engineers in London, England, and was first published in the Institution's Students' Quarterly Journal vol 15 no. 58 p. 22 in December 1944. Also published in The Washington Engineer 1949. |
01-07-2022, 04:38 PM | #32 |
Re: Sign
See the original Turbo-Encabulato here > https://www.youtube.com/watch?v=Ac7G7xOG2Ag
And > https://www.youtube.com/results?sear...or+in+industry
01-07-2022, 06:12 PM | #33 |
Re: Sign
This is a POSTER, here is the poster boy.
01-07-2022, 06:14 PM | #34 |
Re: Sign
Thread Tools | |
Display Modes | |
