08-26-2019, 08:21 AM | #1 |
59AB Block - NOS . . . but I found out why! . . . Help Needed.
A new friend of mine is building his first early Ford - acquired a bunch of really nice stuff from the estate of his late Uncle. Anyway, I helped him sort through stuff and found a 59x block - in NOS condition. Had never been in service! Wow, I've never had one.
Had it cleaned, baked and magged. Was just starting to show him how street porting is done - saw a dang hole in the side of the intake port. Casting issue! This is why it was NOS - because Ford scrapped it! We pressure tested it and I put two lock-n-stitch plugs in the port. Still seeps air in a couple places (too many!) and I don't trust the block at this point (funny casting stuff up in the exhaust port in the same area). One just can't know how bad or extensive the casting flaws are - how far they extend too, etc.. Now that I've seen 4 areas that are blowing bubbles (way down in the port) - not too confident on a build with this block. He wants to do a cross-country trip - can't imagine being in the middle of BFE with water pouring into the cylinder! Yikes! Anyway - the "too good to be true" NOS block . . . is just that . . . it will remain NOS! Good Block Needed!Anybody have a good 39 - 48 - 3 3/16 bore block? I really need one to help this friend out with his very first flathead. I told him he can't risk the thousands of dollars and countless hours of time on his "NOS" one . . . I'm in Columbus Ohio . . . could use some HELP! IMG_7652.jpg IMG_7655.jpg IMG_7678.jpg |
08-26-2019, 09:06 AM | #2 |
Re: 59AB Block - NOS . . . but I found out why! . . . Help Needed.
Wow! What a shame. Hope you find a good block.
08-26-2019, 09:34 AM | #3 |
B&S check with member Chuck Stevens he posted on 8/22/19 in Ziggsters is it worth it thread that he has one for $350 in upstate NY
Cheers Tony |
08-26-2019, 10:58 AM | #4 |
08-26-2019, 11:05 AM | #5 |
It has been my experience that the majority of NOS parts have issues, that is why they were discarded, returned to the original system and then disposed of.
Bill.... 36 5 win cpe |
08-26-2019, 09:44 PM | #6 |
09-03-2019, 06:25 AM | #7 |
I have a 99t block , pressure tested ,magged , sonic tested ,1.6 intakes,1.5 exhaust complete with oil pan , timing cover3 bolt , speedway water pumps short , 8 ss exhaust valves , no guides , 3 5/16 bore. Will include a set of 8 ba rods or a set of floaters with bearings or both if you can use them. $ 500.00 firm and guaranted. Jim
09-03-2019, 06:47 AM | #8 | |
Where are you located, Jim? |
09-03-2019, 04:11 PM | #9 |
Fill the ports up with epoxy & fit ardun heads
<Link> This is how we roll<Link> "I'm Convinced that no one really reads posts anymore; they just fabricate what they think the post says then ramble on about red herrings."--Bob Outcasts rules of old cars #1 Fun is imperative, mainstream is overrated #2 If they think it is impossible, prove them wrong #3 If the science says it impossible you are not being creative enough. #4 No shame in recreating something you never had #5 If it were not for the law & physics you would be unstoppable |
09-04-2019, 07:36 AM | #10 |
