06-29-2022, 05:59 PM | #1 |
Reassembly Questions regarding firewall
I am starting to put my 1957 Thunderbird back together and I have a few questions.
I did not take a good deal of the car apart, so I am flying in the dark as I reassemble it. I just put the dash back in the car and I am attempting the run the wires and cables thru the firewall. I have a large hole where the bushing with several holes (4) goes and I know the wire harness with the two separate wire groups goes there. I do not know what else goes there. On the lower left of the inside firewall there is a large opening in the firewall insulation pad (see photo) inside of that opening there are two small holes in the firewall just above the dimmer switch. I am assuming that one of those is for the left hand air cable. I have no idea what the second hold is for, and I can see no mention of it in any of my many manuals. I hooked up the tach cable. It appears to me that it is a little long, almost to long. Is there several length tach drive cables for the different Ford models? There is an electric connecting block that is located on the front left inter fender. I am unsure of the way the is fastened to the fender. There is a brass insert at each end that are threaded halfway . Are they put on with machine screws from under, or is the threads there to stack them as I have observed in several catalogs? There is a Small hole about 4 inches above the vin number tag .What is that used for? There is also a hole beneath and to the left of the tach coming thru the firewall. How is the speedometer cable routed. When I had received the car the previous owner had taken a few liberty's with the tunnel area sheet metal. Does the Speedometer go thru the tunnel somewhere, or thru the firewall. Any help would be appreciated |
06-29-2022, 07:00 PM | #2 |
Re: Reassembly Questions regarding firewall
Patrick, does your car have windshield washers? Sometime during its life, all of my components had been removed, but the nozzles were still in place on the cowl, below the windshield. After looking at numerous photos and talking to other owners, I determined that the single hole in that location in my 55's firewall accommodates the windshield-washer pump; it's the right size and correct location.
06-29-2022, 07:16 PM | #3 |
The aftermarket firewall cover instructions say that the hole is for the windshield wiper vacuum hose. There were perforations around the area of the hole, which had to be punched/cut out. I have Newport's electric wiper conversion kit (no vacuum hoses). If you have 2 holes, maybe one is for the washer pump, the other for the vacuum hose. I'm not sure how the vacuum hoses are routed. Although I have 2 holes in that area, neither is slotted/elongated, like one of yours. I used one of the firewall cover fasteners in the second hole, which fits like the others, and I don't recall having to make an extra hole in the cover to accommodate the fastener. In other words, I think it belongs there.
06-30-2022, 06:16 AM | #4 |
I do not have windshield washers.I did however install an electric windshield wiper motor.That explains the the hole up near the vin number plate.
Thank you. |
06-30-2022, 06:41 AM | #5 |
I don't know how far into detail this manual gets as I have never read one, but -
Now for a persona question ... How did a person with such a strong Irish name wind up in Alabama?
DIAGNOSED CDO - (OCD In Correct Alphabetical Order) |
06-30-2022, 10:39 AM | #6 |
Patrick brophy, I am starting to put my 1957 Thunderbird back together and I have a few questions. I did not take a good deal of the car apart, so I am flying in the dark as I reassemble it. Same here, someone else took most of this one apart and it was about 2 yrs ago. I just put the dash back in the car and I am attempting the run the wires and cables thru the firewall. I have a large hole where the bushing with several holes (4) goes and I know the wire harness with the two separate wire groups goes there. I do not know what else goes there. The metal 'Left Air' cable also passes thru that grommet. On the lower left of the inside firewall there is a large opening in the firewall insulation pad (see photo) inside of that opening there are two small holes in the firewall just above the dimmer switch. I am assuming that one of those is for the left hand air cable. I have no idea what the second hold is for, and I can see no mention of it in any of my many manuals. I thought those holes may be for the 2 bolts that anchor the forward end of the parking brake rod... but they look too small. I hooked up the tach cable. It appears to me that it is a little long, almost to long. Is there several length tach drive cables for the different Ford models? The Tach cable for a '55 Bird is longer than for a '57. There is an electric connecting block that is located on the front left inter fender. I am unsure of the way the is fastened to the fender. There is a brass insert at each end that are threaded halfway . Are they put on with machine screws from under, or is the threads there to stack them as I have observed in several catalogs? Those RF and LF junction blocks are held to the inner fender with self-tapping sheetmetal screws. Fyi, there are 2 different styles of those double stack junction blocks. The internal connections aren't the same. Photo 4 There is a Small hole about 4 inches above the vin number tag .What is that used for? Do you have a photo of that hole? This car has one there about 3/8 or 7/16 but it's very raw on the edges, not a nice factory hole. I'm planning on having it filled. There is also a hole beneath and to the left of the tach coming thru the firewall. Photo 5, tach cable coming thru the firewall, below the starter solenoid mount location. How is the speedometer cable routed. When I had received the car the previous owner had taken a few liberty's with the tunnel area sheet metal. Does the Speedometer go thru the tunnel somewhere, or thru the firewall. It passes thru a hole in the cowl just above the dash/pedal support bracket. Then down to the top left front of the transmission tunnel and is held to the underside of the floor with a couple small riveted on straps. Example photos 1 thru 3 below. Any help would be appreciated Last edited by dmsfrr; 06-30-2022 at 06:37 PM. |
06-30-2022, 11:31 AM | #7 | |
As far as Alabama goes,I got here as soon as I could but that was 60 years to late. The state is the butt of every joke but after living here for the past ten years ,I will never leave. I moved here from the arm pit of the world, New Jersey. When I arrived here I was welcomed by everyone. My taxes are 10 % of what they were up there, and the cost of living is 40% cheaper. I still get questioned about "my" accent now and again,but I just smile. |
06-30-2022, 11:38 AM | #8 | |
06-30-2022, 03:23 PM | #9 | |
The 'appears to be original' Tach cable on my '57 Bird is approx 44.5 to 45 inches long. Is the Tach cable in your photo inserted thru the firewall correctly? The orange circled knurled ring on the cable I have fastens to the back on the Tach not the distributor. But it looks like you have an after-market distributor so nevermind. In this copy of your photo, the stud marked with an orange arrow is where the original main Ground wire fastens between the firewall and engine block. Excess paint will need to be removed. '57 Birds have a weak link in the original Ground connections from the battery to a pair of small studs just over a foot apart on the firewall then to the engine block. A better solution is to Ground the battery to the left side head or block with a full-sized battery cable. Then a good-sized Ground wire or strap from that terminal on the engine to the stud on the firewall. Similar to how the '55 & '56 body Ground cable was originally done. https://www.ctci.org/battery-cables/ . Last edited by dmsfrr; 06-30-2022 at 06:28 PM. |
06-30-2022, 04:58 PM | #10 | |||
You close to the REDNECK RIVIERA? Quote:
I spent way too much time there and NYC METRO. Quote:
I am glad that you found bliss down south. I do miss those Jersey diners and sub shops though ... You know the difference between a Yankee and a Damn Yankee don't you? A Yankee comes for vacation. A Damn Yankee decides to stay ...
06-30-2022, 07:59 PM | #11 |
Never heard of the O'Hara's at the Tara plantation??
07-01-2022, 02:28 AM | #12 | |
07-01-2022, 06:49 AM | #13 |
Oh do I miss the restaurants,bakerys sub shops etc. But what I miss the most is the great ripper style hot dogs with the good casing hot dog made locally. The diners with the great New York style cheese cake........down here we got Walmart.
07-01-2022, 07:04 AM | #14 |
I am only guessing regarding the tach route.I found the only bushing in the box that could be used that fit over the smaller end the fits the tach end.
Since the cable is fairly rigid and cable attached to the distributor is pointing the direction of the sideways hole in the firewall,and the bushing fit the hole ,I assumed it was correct and used it. Again,in the dark here.is it not correct? |
07-01-2022, 07:35 AM | #15 | |
Were you in North or South Jersey? But I also love Southern Cooking, even Creole to an extent. You know something, hot dogs seem to be out of favor. I love the things. I bought one off a food truck in the Jersey Ports and the guy asked if I wanted kraut on it ... ... I said no but he slapped it on there anyway. I bit into it and it was delicious. Live and learn. Wish I could help with your BIRD, but I never got involved with them.
07-01-2022, 09:25 AM | #16 |
Clinton, New Jersey ,right off route 78.Was an hour out of Manhattan, and an hour and 15 minutes from Philly. Good eats at both locations. There was also quite a few great local restaurants.
07-01-2022, 10:11 AM | #17 | |
In this photo you can see the path taken by the Speedometer cable. . |
