06-27-2022, 10:23 PM | #1 |
1939 Deluxe Window Crank Escutcheon Set Up
So recently acquired 39 Deluxe Coupe.
Window winders not fitted. See attached picture. My question is does the smaller round piece sit atop the larger piece or does it sit inside it. On backside of smaller piece are 4 small tags which line up with the holes in larger piece. Appreciate all advice with this one. Phil NZ |
06-28-2022, 12:06 AM | #2 |
Re: 1939 Deluxe Window Crank Escutcheon Set Up
Those are not 39 DeLuxe escutcheons. The right ones are one piece and have been widely available as reproductions,
06-28-2022, 09:23 AM | #3 | |
From pictures I presumed it was missing so ordered the one on right hand side from Michael at 3rd Generation. I believe these are correct for 39 deluxe by part No: 91A-7022618!! Or am I missing something here? Both door window escutcheons were missing. Deluxe is new to me as I am used to 39 standard. Phil NZ |
06-28-2022, 10:12 AM | #4 |
If it matters to you , the correct handle is dark bronze. The one in your post looks like chrome.
06-28-2022, 10:47 AM | #5 |
06-28-2022, 10:49 AM | #6 |
06-28-2022, 11:31 AM | #7 |
Kube thanks for that. Have studied the 39 Book but also hard to pick up from there. This is an original un-restored car and wish to do it justice.
There are marks on door card which suggests the left hand piece due to larger diameter was fitted to these doors. Phil NZ |
06-28-2022, 11:41 AM | #8 |
The one on the right looks like the right one.
06-28-2022, 11:52 PM | #9 |
06-29-2022, 07:05 AM | #10 |
there was a spring to keep it snug but it makes installing handle harder. (need that nifty tool drake sells) mine fits fine without the spring.
06-29-2022, 11:32 AM | #11 | |
Thanks Phil NZ |
06-29-2022, 12:11 PM | #12 |
The spring goes behind the door panel. You may or may not need one or if you have a nice original car it may already be there.
06-29-2022, 12:50 PM | #13 |
06-29-2022, 01:38 PM | #14 |
06-29-2022, 04:44 PM | #15 |
MEMBER EMERITUS
Phil,
I have a couple of door panel springs you can have - gratis. Chris.NZ. 06 755 0818 |
06-29-2022, 08:00 PM | #16 |
06-29-2022, 08:56 PM | #17 |
redundant post
