Old 06-20-2022, 09:19 PM   #1
[email protected]
Default What headers would I use for duals?
Hi folks. I have a 79 302 ford with a 4bbl edelbrock and edelbrock performer
intake. I found that using lighter springs in the distributor and no vac advance gives max power with 32.5 dwell at 3 grand RPMs. My question IS...
What type headers would I use for more power??? This was a Ford crate engine from Ford. I cannot find if anything special done to it but it is quite
smart for a little 302
already installed with a C-4 in my 55 F-100. 9" ford differential. Thank you
all for the help in the past and now. Jim in Orrington, Maine.
old geezer
jhljr44@yahoo.com is offline   Reply With Quote
Old 06-20-2022, 11:11 PM   #2
miker98038
miker98038's Avatar
Default Re: What headers would I use for duals?
If the peak of the hp curve is 3000 rpm, it’s either a very restrictive exhaust or a pretty mild cam. Most likely both. But while I’ve owned a lot of 4 tube headers, I always thought the tri Y’s gave better mid range torque with a full exhaust system. Don’t know that you can even buy those for your application, but if you’re street driving you’re using that mid range. Torque, not horsepower, is what makes it fun on the street.
What did the torque curve look like on the dyno? Not so much numbers, but peak rpm, and shape of the curve.
miker98038 is offline   Reply With Quote
Old 06-21-2022, 11:46 AM   #3
55blacktie
Are you confusing peak torque with peak horsepower? Peak torque at 3000 rpm is just about right for a stock/mild cam. However, your peak hp should be about 1500 rpm higher/w stock or mild cam.
55blacktie is offline   Reply With Quote
Old 06-21-2022, 03:22 PM   #4
estout81
Try a set of TRI Y 1965 Mustang headers. I have used them on Ranger swaps. They bolt right up no problems. And they are cheap!
estout81 is offline   Reply With Quote
Old 06-21-2022, 04:04 PM   #5
5851a
Just an option but have you looked at early Mustang HP 289 manifolds, good fit, no gaskets. Get a set of ramp lock bolts for them and your good for life.
5851a is offline   Reply With Quote
Old 06-21-2022, 04:28 PM   #6
estout81
Those manifolds are pretty restrictive. They would last a long time! I like headers and the ones I'm talking about have lasted a long time.
Old 06-21-2022, 11:26 PM   #7
55blacktie
The HP 289 manifolds are not the same as those found on A and C-code 289s. They flow better but not as well as Tri-ys that Shelby used.
Old 06-22-2022, 02:27 PM   #8
55blacktie
I can't remember which side, but the 289 HP exhaust manifolds are very similar to one side of the 351W manifolds. Although the 289 HP manifolds are being reproduced, they aren't cheap. You might get the same result for a lot less money by getting a used set of 351W manifolds.
Old 06-22-2022, 03:37 PM   #9
JeffB2
JeffB2's Avatar
Guys in my Ford Group have used these on 302's, they are a copycat of the Patriot H8433's (see picture) https://www.ebay.com/itm/26571879999...UAAOSwvbZimCWL These will fit most standard heads and most aftermarket heads, they are not for the GT40P heads. These hug the block better than the rest. This shows the steering box clearance in a '53 car.
File Type: jpg Chili-size-platter-2-e1420170164660.jpg (37.8 KB, 9 views)
JeffB2 is offline   Reply With Quote
Old 06-22-2022, 03:42 PM   #10
JeffB2
JeffB2's Avatar
Another driver's side view same car.
File Type: jpg Chili-size-platter-2-e1420170164660.jpg (58.3 KB, 9 views)
