12-17-2019, 10:09 AM | #1 |
1932 Window regulator help
Looking for a friend. Need a driver (left) side window regulator for a European 1932 Tudor sedan. They are completely different then then American version. Photos are of the one we need and the passenger side for comparison.
12-17-2019, 06:33 PM | #2 |
Re: 1932 Window regulator help
Have you tried Regulator Roy (http://www.regulatorroy.net/)? Might be worth a shot.
12-18-2019, 07:13 AM | #3 |
you don't show the second side of the good regulator. I can see missing mesh washer on the top of the small drive gear. Appears there is a larger gear also missing and someone tried to move the crank stem. It there a stamp with a company logo that would indicate the manufacturer? How about OD of the missing gears and number of teeth?
12-18-2019, 10:06 AM | #4 |
Hopefully some of our European colleagues will chime in here. My impression is that the survival rate of Briggs-bodied saloons is relatively high, especially in the Scandinavian countries, primarily Denmark. Way back when I spotted six very restorable '32 saloons in a junk yard in suburban Copenhagen and many in everyday use throughout the rest of the country. Surely someone has a usable regulator to spare.
12-18-2019, 10:10 AM | #5 |
I tried to help and only came up with the tudor side window ones. Prewarcars.com is the best bet and place a wanted ad.
12-18-2019, 10:14 AM | #6 |
