Old 09-13-2011, 11:30 PM   #1
dullchrome
dullchrome's Avatar
Default 1948 Ford VIN ID
Can anyone help me break down the VIN on my 48 ?
dullchrome is offline   Reply With Quote
Old 09-14-2011, 07:49 AM   #2
mtflat
mtflat's Avatar
Default Re: 1948 Ford VIN ID
Yeah,............but I can't quite make it out : ) Cars and trucks are different and neither of them tell you very much. It's really just a serial number, not a true vin in the modern sense.
mtflat is offline   Reply With Quote
Old 09-14-2011, 08:58 AM   #3
Capn John
Capn John's Avatar
http://www.vanpeltsales.com/FH_web/f...ialnumbers.htm
1948 Ford V8 - 100hp
Ford 6 - 90hp
Mercury V8 - 100hp
Lincoln V12 89A
8GA
89M
899A-2,071,118 to 899A-2,374,315
87HA- 0,536 to 87HA- 073,901 (i)
899A-2,005,028 to 899A-2,374,315
8H-174,290 to 8H-
see Van's site for placement and further info
Capn John is offline   Reply With Quote
Old 09-14-2011, 10:00 AM   #4
Bruce Lancaster
Note the actual number is just a sequence number assigned in the particular series of engines...
the prefix has the only real info, 8 for '48 model year, 99 or 7H designates which engine, and the "A" following the prefix identifies the vehicle as Ford car. Merc, truck, commercial all had different letters there (M, T, C) but engines were numbered in same sequence. If a V8, your number sequence was actually started in 1939 with the first 239 engines and ended in 1948 as new engine families were started.
Some '48's have a tiny box on the patent plate on firewall giving assembly plant...my export Ford has "ED" for Edgewater.
Bruce Lancaster is offline   Reply With Quote
Old 09-15-2011, 11:38 AM   #5
dullchrome
dullchrome's Avatar
Thanks for the info fellas.
