11-26-2021, 01:15 AM | #1 |
Fuel shut off valve leak
I have a leaking shut off valve in my 1928 35A Phaeton Canadian built RHD. I have taken it apart and have noticed some minor scoring in the lower part of the brass tapered body. Is there away that this can easily and safely be made serviceable and leak proof again? Or should I just purchase a replacement fuel shut off valve?
11-26-2021, 04:25 AM | #2 |
Re: Fuel shut off valve leak
John in Kuranda Australia needs some advice with his leaking Model A Ford Gas Shut off Valve. Can anyone help him out? |
11-26-2021, 07:04 AM | #3 |
11-26-2021, 07:50 AM | #4 |
Timesaver fine lapping compound may be more appropriate. It's made for stuff like that. It still takes time to hand fit valves but it can be done.
11-26-2021, 10:06 AM | #5 |
Try some real fine sand paper or emery cloth.
11-26-2021, 10:35 AM | #6 |
11-26-2021, 10:55 AM | #7 |
After you get it to seal again I recommend you install a gas tank screen (pencil filter). https://www.snydersantiqueauto.com/p...9346&cat=41707
Ruth "Sometimes you really DO need to read the whole thread" |
11-26-2021, 01:03 PM | #8 |
IIRC, Tom W recommended using toothpaste for a lapping compound on fuel shutoff valves.
11-26-2021, 04:31 PM | #9 |
If the scoring is minor, as you say, this will do the trick. I've posted about this one I don't know how many times.
https://www.snydersantiqueauto.com/p...9345&cat=41707
11-26-2021, 04:48 PM | #10 | |
11-26-2021, 06:01 PM | #11 | |
11-26-2021, 07:35 PM | #12 |
See post #11?
11-26-2021, 10:04 PM | #13 |
The OP didn't say anything about it being a replacement valve. I've never seen one of those so I can't comment either way.
