09-30-2021, 10:23 PM | #1 |
1937 aluminum intake problems
I have a 1937 ford pickup that I’ve been using aluminum intake manifolds on and for some reason it keeps burning holes in the back of them or cracking am I doing something wrong or is some repair for this? Thanks
09-30-2021, 11:17 PM | #2 |
Re: 1937 aluminum intake problems
Well Derek, an aluminum manifold made in 1937 is now 84 years old....I too have experienced this problem...one easy solution is to plug the heat riser holes each side of the manifold, either in the block, or in the manifold, or keep trying different manifolds until you find one that works...and welcome, how about some photos of your 37?
10-01-2021, 12:56 AM | #3 |
Derek, Brian has offered a workable solution, for which I can elaborate and also offer a compromise solution...
The heat riser holes in the block are of a size that matches nicely with a penny, to be gently tapped into each of the two holes. Due to the alloys of modern pennies, a wheatstalk penny is recommended. As this fix may cause unwanted consequences, I have a compromise solution to offer... Do as advised above, but also, drill a 1/8" hole in the center of each penny.
Alan |
10-01-2021, 07:37 AM | #4 |
A bit of trivia ......if you can't find a US wheatback, or wheatstalk penny, you can use a US memorial back penny minted from 1959 to 1981, which is the same composition as the "wheaties" pennies. US pennies made after 1982 are 95% zinc and will not withstand the exhaust heat or work for very long.
10-01-2021, 08:18 AM | #5 |
Okay thanks for the information I’ll try to figure out how to put a picture of the truck on here this is my first time using it. I tried the penny trick a year ago but the truck wanted to run really rough and had to be about half choke to run. I thought maybe it was a vacuum leak so I put a gauge on it and it had lots of vacuum. Would drilling the 1/8” hole in the penny help this?
10-01-2021, 08:37 AM | #6 |
10-01-2021, 11:45 AM | #7 | |
10-01-2021, 03:57 PM | #8 |
Okay perfect thanks I’m going to try it out right away!
10-01-2021, 04:01 PM | #9 |
I have another good one but is it at all possible to fix the ones that have burned the holes in them?
10-01-2021, 05:30 PM | #10 |
As a side, in the day, the year of the penny used was your birth year.
10-01-2021, 05:46 PM | #11 |
My truckhttps://imgur.com/a/9XTOaUV
10-01-2021, 05:56 PM | #12 | |
The only thing nice about being imperfect is the joy it brings to others.... "Silver rings, your butt! Them's washers!" "We shot our way out of that town for a dollar's worth of steel holes!" - from 'The Wild Bunch' - 1969 https://www.youtube.com/watch?v=7NReUd2_0u0 Last edited by petehoovie; 10-01-2021 at 06:01 PM. |
10-01-2021, 07:39 PM | #13 | |
Nice looking '37 pickup. I've always felt the '37 PU had the best looking grille in the years from '35 to '39.
10-01-2021, 08:02 PM | #14 |
Thanks that’s awesome I’m working on bringing it back to 100% original I have the frame and motor all fixed up just like new
10-01-2021, 08:54 PM | #15 |
Nice truck! looks like that grill could be fixed with some skillful tinkering
10-01-2021, 09:21 PM | #16 |
Ya actually I bought a 1937 2 ton the rest of the truck was destroyed but the grill or any of the Chrome was perfect pretty amazing. Just waiting for the right time to put it on
10-01-2021, 09:24 PM | #17 |
I’m not sure if it worked or not but this is the new grill |
10-01-2021, 09:25 PM | #18 |
10-02-2021, 05:58 PM | #19 |
Dereck, that's a good lookin' truck, but i believe your front bumper is on upside down.
Tom |
10-03-2021, 10:06 AM | #20 |
[QUOTE=hotcoupe;2062660]Dereck, that's a good lookin' truck, but i believe your front bumper is on upside down.
Tom[/QUOTE You now I think your right I’ve never even noticed that my great uncle had the truck before me and put it on. So is the back bumper supposed to be the same way up as the front one? |
