09-09-2021, 01:44 PM | #1 |
MMO: How much is a little?
Model A has been sitting for 9 months. Want to put a little MMO in cylinders when I have plugs out for clean & checking the gap.
How much is a little? Oz.? Table spoon? Is it best to let it sit in there a day or two? Thanks. |
09-09-2021, 02:14 PM | #2 |
Re: MMO: How much is a little?
I'd just 'glug' some in each cylinder and not worry about measuring it.
Good stuff I use it regularly always in my gasoline. |
09-09-2021, 02:29 PM | #3 |
A few squirts of oil into each hole will do. Spin the engine over to distribute before installing the plugs.
09-09-2021, 02:31 PM | #4 |
I put more then a "little" in my gas tank 2 yrs ago and now seems gooey!!!!!!!!
gooey gas......... |
09-09-2021, 02:38 PM | #5 |
pjdeb - Maybe an oz. in each cylinder but won't hurt if a little more!
Container says ADD 4 oz. MMO to 10 Gals. of gas, is what I do when filling up! |
09-09-2021, 02:51 PM | #6 |
09-10-2021, 10:53 AM | #7 |
09-10-2021, 03:31 PM | #8 |
I have never used MMO, but I might try it. Is there just one kind of MMO? Is the picture below the stuff used in the oil and gas discussed here? BTW, does MMO get old?
09-10-2021, 04:19 PM | #9 | |
Someone correct me if I'm wrong but as long as you keep the lid on snug you're good to go. To me, it is more of a very refined oil on the order of ATF. Plus it smells good! I buy a gallon jug of MMO at WalMart or Farm and Fleet and fill a quart bottle of MMO when it gets empty, to use that to pour into the gas tank. They have handy measurement markings on the side. |
09-10-2021, 06:08 PM | #10 |
A little in the tank and a little in the driver...but then again I'm Irish.
(Do not try this at home)
09-11-2021, 06:25 AM | #11 |
One kind? I don't know, stuff in picture IS used in gas or oil, does MMO get old ? Not if your using it ! I have or had 2 gallons that I had for a long time,refilled into their small bottles .
09-11-2021, 03:15 PM | #12 |
Whatever you put in the cylinders will generally find it's way through the rings by the next morning. I wouldn't put more than 2 fluid oz per cylinder myself but any amount won't hurt anything as long as it doesn't liquid lock when turning the hand crank.
