07-03-2021, 06:23 AM | #1 |
Check this Flatty out
Not mine and stunning!. A friend sent me this pic.If I only had the means.
07-03-2021, 06:27 AM | #2 |
Re: Check this Flatty out
It’s not gunna run that way!
Cheers, Jim&Sandy McGregor, IA |
07-03-2021, 07:50 AM | #3 |
That must be because of the sea-foam green paint and the yellow plug wires! LOL
07-03-2021, 08:31 AM | #4 |
He forgot to connect the coils
07-03-2021, 08:33 AM | #5 |
Outrageously delightful,,,,,,,,it appears as though it is destined for '39 - '41. Loose the
set back intake and go for the Offy clone Speedway 910-15985 CENTER mount 2x2 and 8BA pumps. Allows room for a center mount gen and tucks in w/ room to spare. Only my biased opinion. Charlie ny |
07-03-2021, 08:46 AM | #6 |
Tim Downtown, Ca |
07-03-2021, 09:20 AM | #7 |
I wish I knew more.All that was noted were the ELCO TWIN heads. Curious also as to what the ign is.Looks like SCOT tops on the carbs.
07-03-2021, 09:33 AM | #8 |
I see a lot of money there. Pretty cool.
07-03-2021, 09:59 AM | #9 |
07-03-2021, 10:03 AM | #10 |
If you have enough dough, you can make it go. Looks nice.
07-03-2021, 11:33 AM | #11 |
Yes, distributor is NashTwin8 and they had plans to reproduce it but I think it newer happened...
07-03-2021, 11:40 AM | #12 |
Here's some interesting reading about 'reproducing" the twin 8.
https://www.fordbarn.com/forum/showt...0934&showall=1 And more: Parts are pricey, if available. Check this out. https://www.google.com/search?q=twin...hrome&ie=UTF-8 |
07-03-2021, 11:57 AM | #13 |
Given the horsepower and fuel requirements of almost any engine we'd run in any of our hotrods, there would be extremely negligible increases in HP with dual plugs. Outside of reliability goals (dual coils, dual plugs), I can see no value other than bragging rights.
Now, on modern top-fuel Hemi engines making 8000 HP+, there is a need . . . but that is about it. |
07-03-2021, 12:38 PM | #14 |
Dale the “Kool” factor is way over the top. Looks fast sitting still.
07-03-2021, 02:09 PM | #15 | |
A 'beaut', for sure! But it would look just as fast, yet with way more class if that ghastly yellow was on somebody else's Chevy engine. DD |
07-03-2021, 02:29 PM | #16 |
07-04-2021, 09:04 AM | #17 | |
