Old 04-01-2021, 08:13 AM   #1
corvette8n
corvette8n's Avatar
Default Backfire all the way home
I drove my ‘41 from the storage unit to home about 4 miles, once warmed up it backfired all the rest of the way. It also backfires while it idles. I had Skip rebuild the coil and Charlie NY do the carb two years ago, Tubman condenser, helmet has not been touched. Previous owner put new plug wires. I suspect a valve hanging up as the Reds headers have the paint burning off the driver side but not the passenger side. I have a vacuum gauge and a pressure gauge to check fuel. It has an electric pump and mechanical pump.
As soon as it stops snowing I’ll get it out into the driveway to trouble shoot).
Is there a checklist of where to start?
Old 04-01-2021, 08:50 AM   #2
Ron Pilger
Ron Pilger's Avatar
Default Re: Backfire all the way home
Faulty condensor if I was a betting man.
Ron Pilger is offline   Reply With Quote
Old 04-01-2021, 09:04 AM   #3
Jack E/NJ
Jack E/NJ's Avatar
>>>I suspect a valve hanging up as the Reds headers have the paint burning off the driver side but not the passenger side.>>>
Do you mean a backfire sound or pop from raw gas igniting in the exhaust system, not back up thru the carb? Jack E/NJ
Jack E/NJ is offline   Reply With Quote
Old 04-01-2021, 09:47 AM   #4
corvette8n
corvette8n's Avatar
Sounds like thru exhaust.
Old 04-01-2021, 09:59 AM   #5
tubman
tubman's Avatar
I'll take that bet!
Old 04-01-2021, 10:33 AM   #6
JWL
First step--CHECK COMPRESSION all cylinders.
JWL is offline   Reply With Quote
Old 04-01-2021, 10:59 AM   #7
Charlie ny
8n,
Keep me posted here or at [email protected]
Charlie ny
Charlie ny is offline   Reply With Quote
Old 04-01-2021, 07:15 PM   #8
Angledrive
Angledrive's Avatar
Originally Posted by tubman View Post
I'll take that bet!
Me too!
Angledrive is offline   Reply With Quote
Old 04-01-2021, 08:08 PM   #9
B-O-B
B-O-B's Avatar
Run a QT of MMO or AT fluid thru it before you try anything. KISS
B-O-B is offline   Reply With Quote
Old 04-01-2021, 08:23 PM   #10
rotorwrench
rotorwrench's Avatar
A back fire is where the fire comes back through the intake plenum and carburetor. An after fire is where fuel gets past an exhaust valve and ignites in the exhaust with a loud report. A sticky valve or more is generally the cause. Engines don't like to set for too long. MMO down the carb with some in the fuel might do the trick.
Back fire is generally caused by a lean condition in the carburetor. Occasionally a carbon tracked or cracked distributor cap can cause a cross fire to the wrong cylinder at the wrong time. A bad condenser generally causes a miss fire of one or more cylinders with poor or no idle.
Old 04-02-2021, 02:12 PM   #11
Old Redneck
Old Redneck's Avatar
Send a message via AIM to Old Redneck Send a message via Yahoo to Old Redneck
Clean and check points for gap. Run Carb Cleaner through carb also.
Old Redneck is offline   Reply With Quote
Old 04-03-2021, 01:18 PM   #12
corvette8n
corvette8n's Avatar
So I did a compression test
Drivers side 75,80,80,80
Pass side 75,95,85,75
It was as the car sat since I drove it home, I did not oil the cylinders ahead of time.
Old 04-03-2021, 01:25 PM   #13
corvette8n
corvette8n's Avatar
Here’s what my plugs look like.
File Type: jpg 4898A3CC-0401-422E-8413-666FD2BB7B9A.jpg (41.4 KB, 149 views)
Old 04-03-2021, 02:23 PM   #14
Jack E/NJ
Jack E/NJ's Avatar
Mixture rich. Clean plugs and it'll prolly run fine again. Jack E/NJ
Old 04-03-2021, 05:38 PM   #15
JWL
Basic mechanicals seem adequate. Missing is likely ignition related problem. Plugs are indicating miss firing or over rich condition.
Old 04-03-2021, 06:29 PM   #16
petehoovie
petehoovie's Avatar
The only thing nice about being imperfect is the joy it brings to others....
"Silver rings, your butt! Them's washers!"
"We shot our way out of that town for a dollar's worth of steel holes!" - from 'The Wild Bunch' - 1969
https://www.youtube.com/watch?v=7NReUd2_0u0
