Old 10-30-2020, 05:25 PM   #1
39portlander
39portlander's Avatar
Default 38/39 side hood badges.....
So who might have those little square end bolts that hold the badges to the hood sides. Any input would be great, I have some ideas to make a set but...
39portlander is offline   Reply With Quote
Old 10-30-2020, 05:31 PM   #2
GaryU.
GaryU.'s Avatar
Default Re: 38/39 side hood badges.....
I took some same sized machine head screws and filled the slots with solder, then tin/zinc plated them to try to hide what they started as. Hoping nobody notices.
GaryU. is offline   Reply With Quote
Old 10-30-2020, 06:02 PM   #3
39portlander
That's a good idea Gary, If I can't locate the proper ones was going to braze a dot of solder on a brass bolt and use a square head nut spun to the end of the threads to hold it in the badge.
