Old 06-23-2020, 03:10 PM   #1
First time restorer
Default Hood arm & spring support
Do I need the small bracket that comes on one version of the spring support. The new ones I bought do not have the small bracket that attaches to the firewall.
I read where some 39 Ford Deluxes used that bracket and some didn't.
Thanks
First time restorer is offline   Reply With Quote
Old 06-23-2020, 03:33 PM   #2
Kube
Kube's Avatar
Default Re: Hood arm & spring support
Thanks
Depends... does your car have the two holes in the pinch welded area of the cowl? If so, yeah, you need that small bracket.
Might I ask where you got your supports from?
Only the very early 39 deluxe cars were fitted with the support you describe.
Old 06-23-2020, 03:53 PM   #3
First time restorer
I bought the spring supports from Bob Drake. I do have the 2 holes in the pinch welded area.
Guess I bought the wrong ones. I have the old springs and they didn't have the small brackets.
